Now I wonder if i'm understanding this correctly. Are you saying that if the wizard is set to "gang" and "front" approach, all tool x offsets must be referenced (touched off) the front of the stock? If so, how do you go about referencing a rear facing tool to the front of the stock? I was assuming that by setting a tool as "rear" approach in the tool library, it should be touched off the rear of the stock, even if the wizard is set to "front".
I appreciate your help.
Z Offset Issue with Rear Approach Tools
Re: Z Offset Issue with Rear Approach Tools
you can touch off from either direction as long as cnc12 knows which way the reference tool came from, hence front or rear.
i've got a beta build with the fix, PM me and i'll send you the link so you can try it out.
Keith -- I installed the fix and spent an hour exercising the tool library in various configurations. It looks like the Z offset bug is fixed. Thank you for that! I do have a question about X offsets though: With a rear approach reference tool (wizard set to "Gang" and "Rear"), should the X Ref diameter be entered as a negative value? I think the answer is yes, but please confirm because the manual does not mention negative X Ref values. And, likewise, should the X Ref diameter be left as negative when measuring offsets for (non-reference) tools set to front approach?
Seems like it could be worth adding a gang tool setup sub-section to the CNC12 user manual.
Your primary approach is always positive for X for gang tooling. If the Primary approach is Rear then X will be positive for the rear mounted tools and X Diam will be positive. If the Primary approach is Front then X will positive for the front mounted tools and X Diam will be positive .
Dana
Thank you Dana. I was certainly doing it wrong.
