KP3 cable and wiring
Re: KP3 cable and wiring
hello.
please explain/show when this is happening. are you using a Centroid Probing cycle? or?
Do You have lots of resends in the error log?
Mathes
CNC Control System Serial Number: Acorn E415F6F6BFF1/0503203220 Colchester Lathe
and a Deckel FP1 with Acorn, both with WMPG
Post by Mathes »
Hello all,
I think my brand new probe maybe has a issue, the probe is tripped and stoped during a wall digitizing process.
Whats your opinion, any advice?
Mathias
When it stops like that (mid-digitize, probe tripped, not moving) what is the last status message in the message box? Can you post a screen shot that shows the entire CNC12 screen in that condition?
Mathes
Post by Mathes »
Hello,
yesterday I start the software, and the LEDlight was on from my thes before. I tip with my fingers slighty the ruby ball and the LED turned off.
So, my result is the probe has a issue withe the inner contacts.
Try to do it again next day.
Mathias
Mathes,
Please contact support@centroidcnc.com to return the probe for testing/repair.
KWORK
CNC Control System Serial Number: E062347D8CE7-0513214811 Pro Mill
Post by KWORK »
Hello
se Bulletin 270 I have seen this a lot of time, can't figure out anything here.
But I see a strange thing when I power cycle The acorn.
Start with boot win 10, wait some second, power up Acorn when you look at the Heartbeat led
it gives few blink and then some fast blink and start the one secend Heartblink, now you count the blink,
On blink 3 or 4 you clik on CNC12 icon on the disktop.
Figuret out that 9 out ot 10 times Acorn starts up and can run probing with out any problems.
If you start normal it sometimes seems ok until you want probing.
Hope some one can do some similar with look.
Knud
