Schematic templates available?
Re: Schematic templates available?
rk9268vc wrote: Thu Feb 03, 2022 6:42 pm
ShawnM wrote: Thu Feb 03, 2022 6:07 pm I have and use AutoCAD 2016. Opens the DWG files just fine and I can save as a DXF if needed.
Be aware that autocad saves layers in the dxf. like if the drawing is 5 layers, the dxf will have 5 layers.
If you end up resaving, see if there is a way to save everything as one layer. :)
This is a problem with other cad software which can sometimes only grab one layer, so you will only get some of the lines brought in. Especially with fusion where it wont let you pick which layer to bring in like solidworks does.
I love layers. For me, I would never want everything one one layer. I like the ability to turn layers off and on while I'm drawing as it helps declutter complicated drawings. The only other program I use is the Vectric software and it imports all the layers as I've drawn them. Being able to turn layers off and on makes toolpathing A LOT faster as well. Each tool path is on it's own layer. I do not use Fusion or any other CAD program.
Centroid_Tech2
Post by Centroid_Tech2 »
The schematics are drawn with DraftSight working in paper space or "Sheet Mode".
Fastest1
Post by Fastest1 »
clough42 wrote: Thu Feb 03, 2022 10:58 am I am getting ready to document my Acorn/Ether1616/Avid/Clearpath build on my YouTube channel, and people are already asking me for schematics. Is there a standard template available that I can use to draw them up? I see that all of the schematics on the web site use common components, but I didn't see a template available anywhere.
I watched your video today on this control box. Always like your builds and explanations in general. Cant wait to see the project.
1st Acorn project. G0704/BDTools/Hoss Conversion De"maching"
Leadshine MX 3660
Repurposed above Acorn (#194) and an Ethernet 1616 to a UMC-10 with an 8 position tool changer.
CNC12 Pro/Digitizing ver 4.64 (1/31/2022)
DICKEYBIRD
Post by DICKEYBIRD »
Having watched most of James' videos, I look forward to seeing the content he comes up with on his Acorn project. I'm sure he will bring much enlightenment. Probably sell some more Acorns as well.;)
Milton in Collierville, TN
clough42
CNC Control System Serial Number: 80F5B5F561AB-1001215267
Post by clough42 »
Thanks, everyone, for the help and pointers. I'm slow to respond because I didn't see any notifications. I need to sort that out....
I am currently planning on using the CNC4PC board. If it doesn't work out, there are always options, including spinning my own board.
If you have access to AutoCAD, you can also import the PDFs.
FlySox
Post by FlySox »
Curious what you're using the box for. That's a lot of I/O for only two motors (tool changer?). Whatever it is, I think you'll enjoy Acorn/Centroid, and by enjoy I mean get it put together quickly, maybe do some light VCP customization, and have it just work so you can get on with your projects.
Oops: I see just now that you have been struggling with an Ether1616 issue; so much for my implication that it'll "just work". Still, I think you've picked a solid platform.
