Page 2 of 2
Re: Stepperonline CL86T with Acorn
Posted: Fri May 12, 2023 11:08 am
Shawn and Tom both answered the question very well. Nothing to add here!
Posted: Fri May 12, 2023 12:16 pm
by ShawnM
martyscncgarage wrote: ↑Fri May 12, 2023 11:08 am
Didn't mean to steal your thunder Marty.
I just wanted to point out that the 5V drive DOES still require a resistor if using 24 volts, it just doesn't need to be installed by the builder, it's inside the drive already.
Posted: Fri May 12, 2023 12:18 pm
ShawnM wrote: ↑Fri May 12, 2023 12:16 pm
No worries! I am taking a break from CNC and building Hot Rods...my hands are full.
Thank you for continuing to be active on the forums Shawn/Tom!
Posted: Fri May 12, 2023 12:33 pm
by tblough
No problem Marty. Send some pics of the Rods. I've always been in awe of the artistry you guys are capable of!
Posted: Fri May 12, 2023 1:50 pm
by greglwood
ShawnM wrote: ↑Fri May 12, 2023 10:51 am
greglwood wrote: ↑Fri May 12, 2023 3:50 am
Also would like to note that V4 of the CL86T and CL57T (T Series drivers) no longer require the resistors. The Y Series drivers don't appear to have newer versions.
They do still require the resistor it's just built into V4 and you select 5 or 24 with a DIP switch. The DIP switch is putting the internal resistor inline with your 24 volt input if you choose 24 volts. If you wire it up with 5V then you are in essence taking the resistor out of the equation when you flip the DIP switch to 5V. These are still 5v drives.
I was not implying the internal circuit did not need it, I was implying the user did not have to provide and wire it in.
Greg
Posted: Fri May 12, 2023 5:07 pm
by ShawnM
martyscncgarage wrote: ↑Fri May 12, 2023 12:18 pm
Awesome, enjoy and have a great weekend.
Re: Stepperonline CL86T/CL57T with Acorn
Posted: Thu May 09, 2024 12:38 pm
by ronster
Reading all of the above posts I feel comfortable with my intent on using the "Z" axis CL86T stepper servo wired as the Acorn schematic using the DB25 BoB as drawn. Then, wiring the 2 - CL57T stepper servos for my x & y drives as the schematic is drawn using the H2 header on the Acorn? I realize labeling the correct servos position in software would be necessary.
I think I'm correct wiring as stated.
Posted: Thu May 09, 2024 3:31 pm
ronster wrote: ↑Thu May 09, 2024 12:38 pm
Wire them all to a DB25 Breakout board.
+Pul to DB25 STP
+Dir to DB 25 DIR
-Pul and -Dir to DB25 Ground
Do not connect the enable at this time. Get motors turning first.
These are +5VDC logic drives and should be connected to the DB25
Make sure you tell the Wizard you are using the DB25
Posted: Thu May 09, 2024 6:28 pm
by ronster
Sounds good. Thank you so much!
Posted: Fri May 10, 2024 3:03 am
by suntravel
This thread is old, meanwile I have changed the CL86T to 5V DB25.
