Page 2 of 13
Re: ShopSabre Sidekick 10 Acorn Retrofit
Posted: Sun Dec 12, 2021 11:27 am
by jcoldon
Using the round mount i always wire proximity sen in series . tighten springs it be fine
mine works as it supose to i been using this mount for many years . if it to sencitive adjust the senc down a little closer . then adjust offset setting
. as far as ohmic and water . water gets in the nozel shorts to the shild causing faulice trigger . some time fire torch blow it out
some controllers hafe the ability to fire torch for a mili sec to trier the air .
Posted: Sun Dec 12, 2021 12:28 pm
by ShawnM
jcoldon wrote: Sun Dec 12, 2021 11:27 am Using the round mount i always wire proximity sen in series . tighten springs it be fine
Thanks Jeff, I ended up taking the entire breakaway head apart, adjusted everything and reassembled it. The two prox sensors are wired in series on the "torch breakaway" input. It's working now. Maybe ShopSabre had it adjusted differently for the old WinCNC setup. There were even a few times with the old controller that it didn't trip when it needed to. All good now. I don't have a float switch on this machine.
I reshimmed the mount on the Z axis, squared up the torch to the work surface, adjusted the spring tension, adjusted the alignment cones and adjusted the prox sensors. All seems to be working great now. Working with the new touch off macro from Centroid and I like the check for a shorted tip. I understand that water will close the circuit and I can test fire the torch for a second to dry it out.
I have a 350 piece job Tuesday so we'll see how it runs then.
Posted: Tue Dec 14, 2021 3:17 pm
by ShawnM
Here's the file Keith, I was running this with the "contouring plasma" profile which is the first one of the two on my beta. Of course just change the .txt to .tap to run it.
walker_arm_end_cap.txt
(1.47 KiB) Downloaded 49 times
Posted: Tue Dec 14, 2021 3:30 pm
ShawnM wrote: Tue Dec 14, 2021 3:17 pm Here's the file Keith, I was running this with the "contouring plasma" profile which is the first one of the two on my beta. Of course just change the .txt to .tap to run it.
please use the precision plasma preset for this type of work. thanks,
Posted: Tue Dec 14, 2021 4:30 pm
by ShawnM
But my small holes come out perfect with the "contouring plasma" profile. I know there's purpose for each profile, I need to find a happy medium on the small holes.
Posted: Tue Dec 14, 2021 4:50 pm
ShawnM wrote: Tue Dec 14, 2021 4:30 pm But my small holes come out perfect with the "contouring plasma" profile. I know there's purpose for each profile, I need to find a happy medium on the small holes.
ok great. post a fresh report.zip so we can see the settings being used.
joey is going to cut the program you provided on our machine and we can compare results.
Posted: Tue Dec 14, 2021 5:47 pm
by Joey
Hey Shawn Took a video cutting your Vectric Gcode. I didn't notice much slowing down in the corners. check it out
Posted: Tue Dec 14, 2021 6:05 pm
by ShawnM
Joey wrote: Tue Dec 14, 2021 5:47 pm Hey Shawn Took a video cutting your Vectric Gcode. I didn't notice much slowing down in the corners. check it out
What smoothing profile did you use? Mine was set on "contouring plasma". Mine slowed down quite a bit in the corners, 50% to be exact according to the smoothing profile. When I cut it with the "precision plasma" profile it cuts like yours does. My beta is dated 12/2 and Keith said it was old but another one was probably coming tomorrow. Not sure if yours is newer and has some different changes or not.
There's a video of my cut in my Google folder but it's not as "close up" as yours. I'll finish cutting these parts tomorrow before I update the software since it is actually working at the moment.
Posted: Tue Dec 14, 2021 9:07 pm
by Joey
Shawn, I tried your "Walker Cap" part again after editing The G-Code to cut your inside circle at 75ipm. I came up with 75ipm pretty quick so that could be tuned a little more but it looked pretty good to me. I've included a picture of your G-Code after I set the inside circle to 75ipm. Ive also included a picture of the Profile for you to try out. I tweaked the Feedrate a bit to get a cleaner cut. The steel I'm cutting seems to be thinner than exactly .125inches and is closer to .110. The Anti Dive Velocity is set to 90% so the THC did not turn on during the inside circle cut. Also running the Precision smoothing setting so as to not slow down in the corners as much. Give it a try and Let me know what you think.
Posted: Tue Dec 14, 2021 10:58 pm
by ShawnM
Thanks Joey, I'll have a look and test it tomorrow as I have many more of those to cut. I do remember my ADV was also 90%. I am cutting 14 gauge steel. The cuts I'm getting are very clean compared to before (the old control), I was just hoping to speed it up just a bit around the outside corners for a bit less dross. This was when I started messing with and creating a third profile to try for the best of both worlds.
In your last photo it's super clean but the taper on the hole will never allow a 3/8 bolt in that hole. With the "contouring plasma" profile the holes are EXACT, never been better.
I'll report back tomorrow with any updates.
