routeur cnc acorn auto construction
Filardo
Re: routeur cnc acorn auto construction
Post by Filardo »
Si non samedi dernier j'ai fait les taraudages M10 et M6 qui fixe l'ensemble de ma structure
ok, i'll guess....new it was probably around .125 mm?
looks like a single nut screw designed for a high speed application, not for precision.
you could measure it or find a model number and try to look it up.
Filardo
Post by Filardo »
If not last Saturday I made the M10 and M6 threads which fixes the whole of my structure
Filardo
Post by Filardo »
Je ne l'ai pas encore reçu tous ce que je sais elle était montée sur une panneateuse salvagnini [
Filardo
Post by Filardo »
I have not yet received all that I know she was mounted on a salvagnini panneateuse
exactly. these screw are a good fit for that application. <not high precision>
what is your goal/purpose with the machine you are building?
Filardo
Post by Filardo »
A little amateur violin making and a few precision pieces I haven't really defined all of this yet
Un peu de lutherie amateur et quelques pièces de précision je n'ai pas vraiment encore défini tout ça
Filardo
Post by Filardo »
Je pense gardé cette vis a billes pour axe y
Comme ça elle sera accessible pour pouvoir la changer par la suite si ça ne va pas
I think I kept this ball screw for y axis
That way it will be accessible so that you can change it later if it does not go well
Filardo
Post by Filardo »
Ball screw received heavy cleaning with wd40 then a little spray polishing paste on the lathe
PAs reference on the screw but it is from what I see the model tsl page 129 of the pdf
Vis a billes reçu gros nettoyage au wd40 puis un petit coup de pâte à polir en bombe sur le tour
PAs de référence sur la vis mais il s'agit d'après ce que je vois du modèle tsl page 129 du pdf
CATALOGO_GENERAL_SHUTON_2020 (1) (1).pdf
(11.63 MiB) Downloaded 83 times
Filardo
Post by Filardo »
Photo of the ball screw
Photo de la vis a billes
