Page 2 of 2
Re: CIRCULAR POCKET TOOL OFFSET
Posted: Wed Jun 22, 2022 8:44 am
by suntravel
tblough wrote: Wed Jun 22, 2022 8:21 am Which seems correct - arc moves between +0.288 and -0.288. So (0.288*2)+9.525 = 10.101
jep usually the error is in front of the CNC :)
You will also have to consider, that if Vf F200 on the outside of the bore is needed, in this case write Vfc F11.39 for the G2 moves.
Posted: Wed Jun 22, 2022 8:18 pm
by johnballard
Hi I have attached my circular pocket definition and the incredibly descriptive error.
I'm pretty sure the error is between the keyboard and the floor.
Posted: Wed Jun 22, 2022 9:20 pm
by tblough
Well, for starters, you can't do a 0.5mm finish pass with only 0.576 left on the diameter to take out. Your finish pass can only be 0.288 max and that leaves you no room for ramping on your rough cuts.
Posted: Wed Jun 22, 2022 9:33 pm
by johnballard
OK Tom. Thanks for looking at my pictures. That was it. I feel so ignorant. :oops:
btw until the M6 SHC screws didn't fit, I have let Fusion360 do all my gcode. This was my first attempt with Intercon.
Posted: Wed Jun 22, 2022 11:31 pm
by suntravel
johnballard wrote: Wed Jun 22, 2022 9:33 pm OK Tom. Thanks for looking at my pictures. That was it. I feel so ignorant. :oops:
thats because the circular pocket should be 11mm for the head and 6.6mm bore for the shaft.
IMHO Intercon is faster for simple parts than fusion 360.
