M CODES!
ART
CNC Control System Serial Number: 402E71D16818-0414214669
Re: M CODES!
Post by ART »
eng199 wrote: Fri Sep 10, 2021 4:04 pm Just toss an L1 in there like so:
M130 L1 "C:\cncm\ncfiles\print.bat"
page 13-16 in the v3.16 Mill manual I was looking at
THANKS..I'll be trying it out.
eng199
Re: M CODES!
Post by eng199 »
Also, I didn't see your .bat or .bmp, so I tested with a simple print.bat, just to see that prtLABEL.txt was updating.
test print.bat contents:
type ncfiles\prtLABEL.txt
pause
ART
Re: M CODES!
Post by ART »
eng199 wrote: Fri Sep 10, 2021 4:19 pm Also, I didn't see your .bat or .bmp, so I tested with a simple print.bat, just to see that prtLABEL.txt was updating.
pause
Thanks for your help, the .bat script is in my first post, the forum doesn't let me upload any .bat or .bmp file for some reason.
I tried your previous suggestion and still did not worked out, there is something very weird going on with my plc at this point. I'm running out of hair!! :!:
eng199
Re: M CODES!
Post by eng199 »
I worked with your atest.cnc file.
As I understand it, you had 2 problems:
1. .bat running too many times
2. file contents not updating after each M123
Do you still encounter both problems 1 and 2, or just one, or something else?
ART
Re: M CODES!
Post by ART »
this a screen printing  of how many  .bmp I get after running the gcode
eng199 wrote: Fri Sep 10, 2021 4:35 pm I worked with your atest.cnc file.
Ok, if in M130 L1 in bought iteration nothing happens, no .bat is called.
if I remove M130 L1 from the first iteration but not the second nothing happens, no .bat is called
If I only use M130 normally in 1st an 2nd iteration then I get 4 cmd windows and 4 .bmp but the file name belongs to the 2nd iteration and then I get a final cmd window and 1 final .bmp of the Last M123 or second iteration.
Weird isn't it?
I might need some TeamViewer time.
eng199
Re: M CODES!
Post by eng199 »
I am afraid I don't exactly follow what you are doing. Attached is the test I ran with parameter 150 = 2.
print.bat contents:
pause
I suggest testing like this before using your more complicated .bat with the environment variables, etc.
atest.cnc
(1.14 KiB) Downloaded 63 times
