Huanyang HY03D023B, 12000RPM Max Speed
Re: Huanyang HY03D023B, 12000RPM Max Speed
I don't have a manual. I keep finding this one when I look online.
Here is the closest manual says the dealer.
- HY Series Inverter 20100627.pdf
- (773.09 KiB) Downloaded 75 times
I'm sure there are many more settings once you can find the manual. I'll bet the frequency is probably not set correct either. I've never wired up a VFD that I didn't have to change at least 10 or more settings.
Been looking for a manual for over a year.
PD001 1
PD002 1
PD003 300
PD004 300
PD005 300
PD006 2.5
PD007 20
PD008 220
PD009 15
PD010 8
PD011 200
PD014 15
PD015 15
PD070 0
PD072 300
PD142 8.6
PD143 2
PD144 2000
PD145 2.5
PD176 1
PD001 1
PD002 1
PD003 300
PD004 300
PD005 300
PD006 2.5
PD007 20
PD008 220
PD009 15
PD010 8
PD011 200
PD014 15
PD015 15
PD070 0
PD072 300
PD142 8.6
PD143 2
PD144 2000
PD145 2.5
PD176 1
This manual shows a pic very similar to your VFD on page 14. A better likeness than the manual you posted, no? Found this on my very first search. This can be an issue with Chinese VFD's.
https://bulkman3d.com/wp-content/upload ... Manual.pdf
You have your "min frequency" setting set higher than your "intermediate frequency" setting, try setting PD007 to the factory default of .50 for kicks. I would not have set PD009 or PD010. I would have left PD011 at 0. Not sure how you came up with the value in PD072, default is 50. PD143 should be 4 and not sure how you arrived at PD144.
My advice is to reset the VFD to factory specs and only change the bare minimum to get it moving. Do you have the wizards settings correct for your spindle? I didn't look at your report.
Managed to get it operating but the low will only go to 12500 rpm and not 12000 rpm but 18000 rpm at the highest is correct.
Here is what I have inputted after a reset.
PD001 1
PD002 1
PD003 300
PD004 300
PD005 300
PD006 2.5
PD008 220
PD011 200
PD070 0
PD072 300
PD142 8.6
PD143 4
PD144 3000
PD176 1
PD001 1
PD002 1
PD003 300
PD004 300
PD005 300
PD006 2.5
PD008 220
PD011 200
PD070 0
PD072 300
PD142 8.6
PD143 4
PD144 3000
PD176 1
Does it spin through its full range after a VFD reset and the new settings? Could you be more clear as to what it’s doing or not doing? What do you mean the low will only go to 12500 rpm and not 12000? Post a screen shot of your wizard page for the spindle.
Can you share how you came up with the values in your settings? Some are obvious but a few of them are not. PD004 and PD005 should be 60. I'm still confused by some of your settings.
Edit: PD004 and PD005 would be 60 in the US, not sure about Canada.
My notes on the HY Inverter attached.
Be careful, there are Chinese knock offs of the HY inverter. Usually a give away is no potentiometer on the front panel.
What exactly does the inverter label say?
Consider a TD200 from factorymation.com
- HuanYuang HY Series VFD Setup for 0-10v input 200731.pdf
- (18.31 KiB) Downloaded 89 times
Setting PD004 and/or PD005 at 60, the spindle doesn't run. The VFD was factory reset. The lowest speed the spindle will turn is about 12,500 rpm. If set the speed in Acorn M3 S14000 you get about 14,700 rpm and so on.
From my note sheet I posted. PD005 should be set to the MAX frequency to achieve the highest speed. Try 180 and see what that gets you.
