I know you mentioned you can move the servos using the software, but the other use of that software is you can see what signals the servo is getting.
Might be useful watching to see if the servos actually are getting enabled or not, etc.
Clearpath SDSK not responding to steps (Resolved)
- CNC Control System Serial Number: 0479B7ABE506-0318203048
Re: Clearpath SDSK not responding to steps
- CNC Control System Serial Number: 4681
Thank you Mike and Marty for all your help. I was sure I setup the Teknic motors correctly, but I did a double check and they were not setup for Step+Direction. I think I had changed the setting when I was looking at setting up the home and limit switches and forgot to set this back again. Now my X-Axis is working, so I will reinstall the C86ACCP and hopefully everything will work correctly.
Thank you to everyone for all your help.
Regards,
John
Regards,
John
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Glad you are moving forward John.john3909 wrote: ↑Tue Jul 13, 2021 8:22 pm Thank you Mike and Marty for all your help. I was sure I setup the Teknic motors correctly, but I did a double check and they were not setup for Step+Direction. I think I had changed the setting when I was looking at setting up the home and limit switches and forgot to set this back again. Now my X-Axis is working, so I will reinstall the C86ACCP and hopefully everything will work correctly.
Regards,
John
Hi Marty,
Reinstalled C86ACCP and all axis are working. Thank you again.
Regards,
John
Regards,
John
Great!
Re: Clearpath SDSK not responding to steps (Resolved)
Glad it works! Worth noting, this sort of thing is part of why I love having the USB interface on the cleapaths. If you see the enable signal and commands coming through on the A and/or B inputs, your troubleshooting is very different from if the signals aren't even getting there.
