Bridgeport series 1 centroid CNC4 to acorn conversion
- CNC Control System Serial Number: Acorn 4882
Re: Bridgeport series 1 centroid CNC4 to acorn conversion
As far as setting up the acorn for permanent use, Im going to mount the main board and relay board in the original centroid CNC4 motion controller box. Even if I end up with different drives it's a nice solid box with main power switch and e stop I'll be using. I would think I could set it up to use the command buttons on it I if I wanted to although I have touch screen.
The driver and logic boards in the motion controller are 8 3/8" to fit the slots in the enclosure chassis. I figure I'll get a sheet of some sort, plastic, phenolic or aluminum cut to fit the chassis , and mount the boards on it on standoffs.
Should I be concerned about RF noise with the acorn being mounted close the the motor drivers and in an enclosure with 2 power supplys, the original motion controller/drive power and the meanwell rd-35b? Would an aluminum plate to mount the boards be a bad idea?
A metal enclosure and a metal mounting plate is recommended.
Where do you find/buy these NEMA 42 Leadshine Easy Servos? I can't find them online. And not on Leadshine's website. Do they call them something else?BDubs wrote: ↑Thu Jul 01, 2021 6:09 am Leadshine makes a really nice NEMA 42 Easy Servo motor and drive that's hard to beat. It's a closed loop stepper. Bolts right up aside from maybe needing a different size taper lock. Save yourself a lot of agg by not putting N34s on it. It's not a place to scrimp. Otherwise you wind up buying motors twice... been there done that.
Ok, I'm working my way through this and I want to try to set it up right. My drives and vcc/ground are on a 26pin IDC ribbon connection with a 3 way cable already. Would It be wise to get a break out board like this to run jumpers to the acorn or can I just strip and separate the end on the ribbon to set in the acorn screw terminals? Those wires sure are tiny. If I go with the breakout board would a solid copper phone wire type be good for the jumpers from the breakout to the acorn?
Unless it is a shielded ribbon cable, I think that is going to cause problems. You really want your step and direction wires to be shielded twisted pair cables.
You should never use solid hook up wire in a machine tool. Vibration will cause the wires to break at the connection. Best case is they break and fall off. Worst case is they break and the insulation holds it together and you end up with an intermittent connection that is impossible to diagnose.
Automation Direct, McMaster-Carr, Digikey, and Mouser Electronics are a few places where you can buy 18ga stranded MTW (Machine Tool Wire) for your connections.
- CNC Control System Serial Number: 1923
Jason, getting ready to do the same retrofit. Did you take everything out of the CNC4 box and just leave the drives? Also I'm thinking of using a Intel NUC as my computer thoughts.
I would assume it's sheilded ribbon cable. It's all original parts from a centroid CNC4. The jumper wires being a twisted wire does make sense for though. The computer is not mounted to the machine and shouldn't really vibrate. I think there is a pile of wire in the original CNC PC I could scavenge plus ive got a couple old PC laying around as well. Thanks for the advice. I'll look into that wire as well.tblough wrote: ↑Sun Dec 18, 2022 9:03 am Unless it is a shielded ribbon cable, I think that is going to cause problems. You really want your step and direction wires to be shielded twisted pair cables.
Yes my plan is to remove the other boards from the CNC4 enclosure and build a new board that fits the chassis slot with the acorn parts mounted on it, plus a new rear plate to cover it all up. I'm leaving the fan and power supply for the drives and motors obviously. The estop button can be tied in directly to the acorn. I believe that the same power cord could be tied into the acorn provided power supply for simplicity as well but I'm looking into that. I don't think you want the CNC4 power switch to kill power to the acorn board .Darrell Hall wrote: ↑Sun Dec 18, 2022 7:34 pm Jason, getting ready to do the same retrofit. Did you take everything out of the CNC4 box and just leave the drives? Also I'm thinking of using a Intel NUC as my computer thoughts.
I have no computer knowledge to pass on except that they use a Intel NUC in the setup/bench test videos so I would say it's a very good idea. I had my brother build me a touchscreen laptop with the requirements set by centroid so that saved me a pile of money.
