I have another DXF and I'm not sure where the resolution problem is coming from...it could be the monitor, but when I import the file has jagged lines and the arc that is highlighted should be closed by the adjacent curve - it seems to extend beyond so I can not create a pocket.
I have included a picture and the file. I have tries several option during the export - different versions 13 & 14, exporting as curves and splines; no difference in CNC12
DXF Requirements??
Re: DXF Requirements??
- cnc_backup_402E71CADC40-0323214550_2021-04-30_11-38-36.zip
- (472.21 KiB) Downloaded 93 times
- cw_roller_2-c.zip
- (2.64 KiB) Downloaded 98 times
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
- CNC Control System Serial Number: ok 375
Hello. Keith
I am new to the forum, and I have seen the videos of the import of the
dxf files and in my system acorns 12v4.50 I do not see the
DXF key how can I fix this problem.
Regards.
Judah
Regards.
Judah
You need to get upgraded to 4.64
Thanks.
Keith.
Regards.
Juda
Keith.
Regards.
Juda
Looks like this is probably some setting in your CAD system on how it does circles.lavrgs wrote: ↑Sat May 01, 2021 5:01 pm I have another DXF and I'm not sure where the resolution problem is coming from...it could be the monitor, but when I import the file has jagged lines and the arc that is highlighted should be closed by the adjacent curve - it seems to extend beyond so I can not create a pocket.
I opened his DXF file in a text editor, and in Visual CADD. It does contain circles, not polygons.
Hello. Marty.
I am trying to run my mill converted to cnc with centroid version 12v .5 software and using the fusion 360 post processor.
I already generated a cam in fusion to run with the probe in a fixture
everything is fine but I can't generate the G codes for centroid
could you support me
Attached I send screenshots and a video of how the program runs in fusion 360, but I cannot generate the G codes
for centroid.
greetings and I hope your prompt help.
Judah.
for centroid.
Judah.
- Medicion de fixture.rar
- (10.19 MiB) Downloaded 89 times
I have no experience with your software. Your question are software specific.
