spindle on on tool change (Resolved)
chessie
Re: spindle on on tool change
Post by chessie »
i have it ,any particular page ?
as im new to this, i came to this forum for help
chessie wrote: Mon Feb 22, 2021 1:05 pm i have it ,any particular page ?
Right here is fine!😁
I am guessing that when Marty directed you to the Operator's Manual, it was to look at the T code in Chapter 9; to look at M0 and M5 in Chapter 11; and to notice the absence of M6 in Chapter 11 (M6 is a mill code, not a lathe code).
chessie
Post by chessie »
ok thanks, but if i type m0 in the mdi nothing stops
i type m6t303 it does
so something is wrong with something ,i just need some help as to what it could be
cncsnw wrote: Mon Feb 22, 2021 3:27 pm
Yes, thanks Marc.
While I understand its a rather large manual, it is worth reading through. It goes over setting up tool offsets, part zero's, there is a table with the M codes and G codes.
M3=Spindle Forward
M4=Spindle Reverse
M5=Spindle Stop
T0101= Change to Tool 1 offset 1
T0202=Change to Tool 2 offset 2
chessie wrote: Mon Feb 22, 2021 4:11 pm ok thanks, but if i type m0 in the mdi nothing stops
On a lathe you do NOT put in an M6
Simply the tool number and offset number
T0101 Cycle Start
Try it in MDI
chessie
Post by chessie »
just so we are all on the same page
mdi m3 ,m4,m5 sxxx m8 all work fine
t0101 ect changes the tool on the screen but does not stop the spindle/coolant or move the tool post to the g28 position (check tool)
and with motor/ coolant on, etc m0 does nothing when typed into mdi
so if the pp format is correct then i guess something is not right with the control set up .
Any ideas ?
chessie wrote: Tue Feb 23, 2021 12:12 pm just so we are all on the same page
Any ideas ?
Yes, your Gcode needs to be formatted accordingly. Its not the Centroid Control.
Try a Fanuc 0T post processor.
Marc Leonard (cncsnw) has some info on his website: http://www.cncsnw.com/PostProcessorsLathe.htm
Search the forum here for Centroid Lathe Post Processor. I think a couple of guys have worked on them.
chessie
Post by chessie »
thank you
i just ran the mm encoder pawn program , i had to make a change because the version that came with the software still had g20 not g21
after i changed it it ran and did the tool change properly
So im just after a lathe pp for fusion now that works
thanks for your help
