Re: 4.6 UPDATE WENT BAD!! HELP!!
Posted: Sun Jan 31, 2021 3:39 pm
That will take a LONG awhile to format.
I trust you followed the instructions in the link I sent implicitly?
Was the first thing I did, crazy.martyscncgarage wrote: ↑Sat Jan 30, 2021 10:35 pm Also, you might pull ALL the plugs on Acorn except the power plug and Ethernet and see if you have a heartbeat on power up.....(Blue light to the right of the ethernet connector on Beagle Bone Green, pulses rapidly on first power up and then 1 pulse per second, the heartbeat)
JUST to be sure....
Yesmartyscncgarage wrote: ↑Sun Jan 31, 2021 3:39 pmThat will take a LONG awhile to format.
Interesting, I have had no communication problems all this week as far as I know. I will address it this week after I get the BBG plugged back in.martyscncgarage wrote: ↑Sun Jan 31, 2021 6:50 pm You also MUST address the communication errors. This could be why your Acorn bricked:
From your error logs:
(4) 01-28-2021 14:17:44 944 MPU requested resend # 767
(4) 01-28-2021 14:17:44 946 PC resending # 9654
(4) 01-28-2021 14:17:45 944 MPU requested resend # 768
(4) 01-28-2021 14:17:45 946 PC resending # 9666
(4) 01-28-2021 14:17:46 944 MPU requested resend # 769
(4) 01-28-2021 14:17:46 946 PC resending # 9669
(4) 01-28-2021 14:17:46 944 MPU requested resend # 770
(4) 01-28-2021 14:17:46 946 PC resending # 9675
(4) 01-28-2021 14:17:48 944 MPU requested resend # 771
(4) 01-28-2021 14:17:48 946 PC resending # 9688
(4) 01-28-2021 14:17:49 944 MPU requested resend # 772
(4) 01-28-2021 14:17:49 946 PC resending # 9693
(4) 01-28-2021 14:17:51 944 MPU requested resend # 773
(4) 01-28-2021 14:17:51 946 PC resending # 9696
(4) 01-28-2021 14:17:51 944 MPU requested resend # 774
(4) 01-28-2021 14:17:51 946 PC resending # 9700
(4) 01-28-2021 14:17:51 944 MPU requested resend # 775
(4) 01-28-2021 14:17:51 946 PC resending # 9709
(4) 01-28-2021 14:17:51 944 MPU requested resend # 776
(4) 01-28-2021 14:17:51 946 PC resending # 9711
(4) 01-28-2021 14:17:51 946 PC resending # 9714
(4) 01-28-2021 14:17:52 944 MPU requested resend # 777
(4) 01-28-2021 14:17:52 946 PC resending # 9723
(4) 01-28-2021 14:17:54 944 MPU requested resend # 778
(4) 01-28-2021 14:17:54 946 PC resending # 9729
(1) 01-28-2021 14:20:41 204 Exiting CNC...Normal Exit (66)
(1) 01-30-2021 13:25:32 199 CNC Started
(4) 01-30-2021 13:25:36 944 MPU requested resend # 8
(4) 01-30-2021 13:25:36 946 PC resending # 415
(1) 01-30-2021 13:25:39 CNC12 Acorn Router v4.59 BETA, Rev 12 URL: /cnc11/branches/acorn R11935 clean Dec 17 2020, 13:40:09
(4) 01-30-2021 13:25:41 9033 Reset Initiated, Press Reset to Clear
(4) 01-30-2021 13:25:41 944 MPU requested resend # 9
(4) 01-30-2021 13:25:41 946 PC resending # 426
