Eric V wrote: ↑Fri Apr 30, 2021 11:13 pm
Hello all,
Followed tech bulletin and Centroid CNC Technical Support video and all good
up to the compile command. Here is the error:
"C:\cncm\compile.cmd""acorn_mill_plc.src"
Process started (PID=9428) >>>
'"C:\cncm\compile.cmd""acorn_mill_plc.src"' is not recognized as an internal or external command,
operable program or batch file.
<<< Process finished (PID=9428). (Exit code 1)
================ READY ================
Files seem to be in the right directories. Not sure what to fix.
Any help would be appreciated!
Always post a fresh report. Explain why you are making a modification to the PLC. What are you trying to accomplish? Acorn system?
Re: Notepad ++ Compile issue
Posted: Sat May 01, 2021 11:07 pm
by Eric V
Hi Marty,
Sorry for not posting the report. Here is the report and link to photo gallery.
I didn't plan on changing the current PLC file. I am interested in setting up
Notepad++ for future changes in needed.
I did work through that bulletin. At number 10, is when I got the compile error.
Posted: Sun May 02, 2021 7:50 am
by tblough
Are you using Command shell or Power shell?
Posted: Sun May 02, 2021 9:07 pm
by Eric V
Not sure. It is the console which is opened inside notepad++.
Posted: Sun May 02, 2021 9:43 pm
by tblough
"$(CURRENT_DIRECTORY)\compile.cmd" "$(FILE_NAME)"
Did you include the space between the two quoted arguments?
Posted: Mon May 03, 2021 2:58 pm
curious about what custom mods you are making to the Acorn PLC program, tell us about them.
Posted: Mon May 03, 2021 11:26 pm
by Eric V
Tom,
That was the ticket! Thanks!!
Hi Keith,
I am not making any changes now. I was just setting up notepad++ for future use.
If I come up with a helpful PLC, I will be sure to share.
Thanks for asking!
Re: Notepad ++ Compile issue (Resolved)
Posted: Sun Jun 26, 2022 10:36 am
by Spartan117
It seems like the link to the notepad++files-zip in the TB294-1 (Configuring Notepad++) is broken:
