Page 2 of 2
Re: MPU11/GPIO4D using encoder expansion board not all of info
Posted: Sat Jan 02, 2021 9:44 pm
by Poorboy
report_0406120519_2021-01-02_20-19-02.zip
(5.29 MiB) Downloaded 7525 times
report last
Posted: Sun Jan 03, 2021 1:15 am
by cncsnw
Interesting.
From your "mpu_info.txt" file, which lists the hardware detected on boot-up:
******MPU Info******
TimeStamp 2021-01-02 20:11:33
DSP  version 414.000
FPGA version 0.59
 DriveNumber DriveType                      Version1 Version2
           1 NONE                                  2      ---
           2 NONE                                  2      ---
           3 NONE                                  0      ---
           4 NONE                                  0      ---
           5 NONE                                  0      ---
           6 NONE                                  0      ---
           7 NONE                                  0      ---
           8 NONE                                  0      ---
           9 GPIO4D                                4      ---
          10 GPIO4D                                4      ---
          11 GPIO4D                                4      ---
          12 GPIO4D                                4      ---
          13 NONE                                  0      ---
          14 NONE                                  0      ---
          15 NONE                                  0      ---
          16 NONE                                  0      ---
          17 NONE                                  0      ---
          18 NONE                                  0      ---
          19 NONE                                  0      ---
          20 NONE                                  0      ---
          21 NONE                                  0      ---
          22 NONE                                  0      ---
          23 NONE                                  0      ---
          24 NONE                                  0      ---
          25 NONE                                  0      ---
******PLC Info******
PLC Version 4
PLC Device GPIO4D (7)
    Inputs Device                                    Port
   1-16    DIGITAL_IO (2)                               0
  17-32    DIGITAL_IO (2)                               0
  33-48    UNIMPLEMENTED (0)                            0
  49-64    UNIMPLEMENTED (0)                            0
From the mpu_info.txt file on one of my installations, which uses an ENCEXP board connected to an Oak:
TimeStamp 2019-02-01 16:21:45
DSP  version 413.003
FPGA version 1.2
           1 ENCEXP                                1    3.009
           2 OPTICDIRECT                          12      ---
           3 OAK                                   4      ---
           4 OAK                                   4      ---
           5 OAK                                   4      ---
           6 OAK                                   4      ---
           7 NONE                                  0      ---
           8 NONE                                  0      ---
           9 NONE                                  0      ---
          10 NONE                                  0      ---
          11 NONE                                  0      ---
          12 NONE                                  0      ---
          13 NONE                                  0      ---
          14 NONE                                  0      ---
          15 NONE                                  0      ---
          16 NONE                                  0      ---
          17 NONE                                  0      ---
          18 NONE                                  0      ---
          19 NONE                                  0      ---
          20 NONE                                  0      ---
          21 NONE                                  0      ---
          22 NONE                                  0      ---
          23 NONE                                  0      ---
          24 NONE                                  0      ---
          25 NONE                                  0      ---
PLC Version 4
PLC Device OAK (15)
    Inputs Device                                    Port
  17-32    PLCADD1616 (5)                               0
  33-48    PLCADD1616 (5)                               1
Your MPU11 is seeing something there (implied by the non-zero major version number) but does not recognize it as an ENCEXP. Perhaps you need to get the MPU11 board firmware updated. I recommend putting the question to Centroid tech support on Monday.
Posted: Sun Jan 03, 2021 10:57 am
by Poorboy
Ok thanks
Re: MPU11/GPIO4D using encoder expansion board not alot of info of info
Posted: Sun Jan 03, 2021 12:19 pm
by Poorboy
Well I tried!
So I decided to completely uninstall all the software and reinstall a fresh download of 4.14 cnc12.
I restored all the files and turn all my unlocks back on. Now the system performs like it did before.
The only thing that doesn't work is the expansion board. Same issue as listed above not recognized on bootup.
I there a way to force firmware install?
Posted: Sun Jan 03, 2021 5:22 pm
by cncsnw
If firmware is the issue, then you will need to send the MPU11 board to Centroid to be updated. That is not part of a CNC12 software update.
You can confirm that by seeing whether the "FPGA version" number in your mpu_info.txt file has changed.
Posted: Mon Jan 04, 2021 10:27 am
by eng199
The board is set up as ENCEXP2. This is a newer version that is not recognized by software prior to 4.15 r5. Your best option is to upgrade to CNC12 4.16. Contact tech support to sort out any issues you may have with the new license system on 4.16.
Posted: Tue Jan 05, 2021 6:48 pm
by Poorboy
Well
centroid hooked me up with a firmware upgrade and fixed the issues with the encoder expansion board.
thanks for you help.
now its time to put my new allin1dc to work on my romi bridgeport lathe.
