lathe probe\offset with boring bars
Caleb
CNC Control System Serial Number: 780473A2EE6C-1022192587
Re: lathe probe\offset with boring bars
Post by Caleb »
Anyone managed to have a look at this yet?
Caleb wrote: Wed Mar 25, 2020 5:16 pm Anyone managed to have a look at this yet?
It is a bug in 4.20.1.
It is being worked on for the next release.
It was fixed...then got broke again so they tell me. :oops:
Caleb
Post by Caleb »
I'm On V4.5
It works now for Bore ID Front
It still doesn't work for ID Tread Front, I still have to subtract the Probe diameter from the measured .
Caleb
Post by Caleb »
Bumping the thread up, like the measured threading tool in to the job...
Caleb wrote: Wed Jul 22, 2020 3:17 am Bumping the thread up, like the measured threading tool in to the job...
Please post a fresh report. I've asked Centroid to take a look, but they will likely want to see a report.
Caleb
Post by Caleb »
Of what I have tested and recorded on X measurements I've not double checked Z
ID Bore Front Vector 2 measures correctly
FFace Bore Front Vect 7 does not account for Touch off tool dia
FFace Bore Front Vect 2 does not account for Touch off tool dia
FF Bore Custom Vec 2 doesn't account for Touch off tool dia
ID Bore Front Vector 7 Measures x in wrong direction
ID Thread Front vect 6 does not account for Touch off tool dia
ID Thread Front vect 7 does not account for Touch off tool dia ad Measures x in wrong direction
Report attached
report_780473A2EE6C-1022192587_2020-07-28_11-11-52.zip
(775.79 KiB) Downloaded 137 times
Caleb
Post by Caleb »
Any update?
pm me if you want to sign a beta software agreement and help sort this issue out
Caleb
Post by Caleb »
Pm sent
Caleb wrote:ID Bore Front Vector 2 measures correctly
I do not have a suitable testbed, and have not had time to look at this myself, but Caleb's account above is disturbing.
The nose vector, and only the nose vector, should determine both the movement direction for measurement, and whether to compensate for the width of the touch-off device. The "Tool Orient" and "Tool Type" fields are just conveniences to aid the user in choosing the right vector, and perhaps hints for the runtime graphic display to show a suitable outline.
When measuring X offsets:
- Nose vectors 3, 4 and 8 touch off as OD tools (from the X+ side, moving in the X- direction)
- Nose vectors 1, 2 and 6 touch off as ID tools (from the X- side, moving in the X+ direction)
- Nose vectors 5 and 7 cannot have their X offsets automatically measured. The software should report an error and refuse to measure.
Similarly, when measuring Z offsets:
- Nose vectors 2, 3 and 7 touch off as front-side tools (from the Z+ side, moving in the Z- direction)
- Nose vectors 1, 4 and 5 touch off as back-side tools (from the Z- side, moving in the Z+ direction)
- Nose vectors 6 and 8 cannot have their Z offsets automatically measured. The software should report an error and refuse to measure.
