Wireless MPG CWP-4 won't jog Z axis
Dan M
CNC Control System Serial Number: C8df84dfbdd5-0809181120
Re: Wireless MPG CWP-4 won't jog Z axis
Post by Dan M »
mlegary wrote: Fri Apr 26, 2019 4:18 pm I changed the input for my limit switches to unused and the same issue occurs. Z will not jog on the wheel and requires reset to allow other axis to jog. Z does move correctly with the Jog +/- buttons still.
Just for to rule it out have you tried switching USB inputs for the MPG?
I ask because I just recently got a MPG was working great and then yesterday it stopped working. I spent half the day updating windows and making sure my Lenovo was updated as well as all the drivers.
I finally switched the USB port and it's back to working.
In my case I was getting a pop up saying MPG is enabled but no MPG is detected or something along those lines. The weird thing is that the MPG was showing it was getting a signal and before I got the pop up the MPG was still showing CNC Centroid and the dro was showing up but I got no response to the hand wheel as well as the buttons.
Then after exiting and turning it off and on and unplugging it I started getting the pop up. I tried rebooting, cycled the Acorn, rewrote the wizard settings and in the end it was the USB port. Haven't looked into weather or not other USB devices work on that port yet but I will today since I'm curious what would cause it to suddenly stop working. Sorry for the long rambling reply but maybe you'll get lucky and it's just the port like mine was.
Dan
mlegary
CNC Control System Serial Number: 74E1829FAAEB-0307191745
Post by mlegary »
No luck, switched inputs, rebooted, still the same issue.
Dan M
Post by Dan M »
Lame, hopefully it's something simple and the MPG didn't break. BTW I plugged my mouse into the port that stopped working with the MPG and it didn't work. So some how the port went bad on the PC, very strange but it's a referb PC so who knows. Let us know if you get it fixed. You may want to call Centroid and have them look at it. It sounds like you're just spinning your wheels at this point.
Dan
mlegary
Post by mlegary »
Yeah, it does seem like a software or config thing with my installation of the acorn.
The fact that the Z axis jogs with the Jog +/- buttons means the axis and control of axis works. The jog wheel interaction causes something to require a reset in CNC12.
cnckeith wrote: Mon Apr 29, 2019 5:26 pm i suggest a team viewer session.
Make sure you have TeamViewer 12 on the Centroid PC. Then PM Keith to establish a time and date so he can try and help.
If you've read done that, disregard.
