I like that one "traverse the country" so true.. That's some funny ish right there.
MPG not working. < fixed >
- CNC Control System Serial Number: C8df84dfbdd5-0809181120
Re: MPG not working. < fixed >
Re: MPG not working. < not fixed >
Thanks Marty, Pro installed, But MPG still not working. It sees the position on the led but when I press the button on the screen to jog with the mpg it does not change. Jogging by pressing on screen buttons work but turning the mpg wheel does nothing. I restarted, acorn, restarted the control and re booted the computer with no change.
Kitmill,
Does it work on any of the speed selections, x1, x10, or x100, when selected on the MPG pendant?
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Go back into the Wizard and make sure it IS enabled after you installed the license.TheKitMill wrote: ↑Fri Mar 29, 2019 11:29 am Thanks Marty, Pro installed, But MPG still not working. It sees the position on the led but when I press the button on the screen to jog with the mpg it does not change. Jogging by pressing on screen buttons work but turning the mpg wheel does nothing. I restarted, acorn, restarted the control and re booted the computer with no change.
It will not enable if the license isn't installed.
If it was not enabled, enable it, write settings, power down the control and PC. Turn on the MPG and power everything back up.
There have been no reports of others having trouble with the MPG after the 4.14 upgrade that I am aware of. Might be something simple.
Thanks Marty I shut down everything after rechecking the setting booted back up started Acorn and it is now working. Problem solved thanks
Only other issue so far is that it keeps reverting back to bench test when I use the wizard to reset all everything to what was working before the upgrade. I am no longer getting a Custom Dmm4 set up notice it just reverts back to bench test mode. Am I missing a step
Please start a new thread, post a report, describe the machine. Making a video of it doing what you are describing would be very helpful.TheKitMill wrote: ↑Fri Mar 29, 2019 2:08 pm Thanks Marty I shut down everything after rechecking the setting booted back up started Acorn and it is now working. Problem solved thanks
