Bridgeport R2E4 W/DMM DYN4 Servos not reversing
Woburn
CNC Control System Serial Number: C8FD19F2215B-0404180798
Re: Bridgeport R2E4 W/DMM DYN4 Servos not reversing
Post by Woburn »
Ok, thanks. I will reach out to DMM for better understanding why the recommendation to deviate from your schematic. And why others are able to get by with 5v supplied to pin 11 and 22.
We tested the DYN4 to Acorn cable made by DMM today. It works. Please see schematic attached.
ACORN_DYN4_with_DMM_CABLE.pdf
(99.95 KiB) Downloaded 209 times
follow previous software setting instructions with these differences..
Set Gear number to 2000 in DMM software
and use 8000 steps per rev in the Acorn Wizard
lilb93
CNC Control System Serial Number: 0216041209
Post by lilb93 »
will this work with rev. 2 board?
Barnesville, PA.
I always thought it would take longer to grow old.
Yes should be no issue.
I tested the cable yesterday myself and did a video on it.
https://youtu.be/TMxjRL7YXXw
Be sure you have DYN4 configured and tested using the DMMDRV software first
great video marty!
i made up a pdf as a reference to go with the video.
DYN4 Acorn setup draft rev1.pdf
(766.24 KiB) Downloaded 198 times
