Anilam (Baldor) DC Servo Power
jaystew324
Re: Anilam (Baldor) DC Servo Power
Post by jaystew324 »
Hello,
I just ordered an Allin1DC to retrofit my Anilam 1100 as well. Just wondering if you ended up needing a step down transformer or if you were able to run the 160VDC directly.
thanks,
Jason
CRM
CNC Control System Serial Number: A900171
Post by CRM »
The initial config included a step down X-former. I could not achieve full rapid speed, so I took it out and am running about 6 volts above the max rated voltage for the servos. I do this at my own risk.
Dean Jahnz
Cannon River Machine
jaystew324
My servos show a max voltage of 140VDC on the name plates. If I rectify the 120VAC line voltage I would get 168VDC (120VAC x 1.4 = 168VDC). As far as I can tell this seems to be what Anilam did because I do not see a large transformer anywhere in the cabinet. Could they really have been running 28VDC over the motor rating? Seems like a lot to me. Am I missing something?
thanks for your help,
Jason
CRM
Post by CRM »
Centroid will say for liability reasons that you need a step down transformer. So that's what I did at first. But I could not achieve the rapid speeds I had prior to swapping the old Prototrak control with the All In One DC control. Further inspection showed SouthWest Industries was using direct rectification, so I eliminated the step down X-former, after which I could again achieve 150 IPM rapids. I believe my previous posts show a pic of the servo motor nameplate, (Magnetek, 140VDC). That would be comparable with your Baldors.
Dean Jahnz
jaystew324
Thanks for your help. I guess I'll give it a shot directly rectifying the line voltage. Fingers crossed that I don't smoke a servo.
CRM
Post by CRM »
It is my understanding that you won't get full current unless you are loading at near full thrust. Lots of rapids ot motion reversals. Feel the servos for heat build up.
Dean Jahnz
