New to Board/New Build: PM30-MV Mill, Acorn, CNC12 pro, DMM DYN4 & .75KW SERVO X/Y/Z, DMM SERVO SPINDLE !!
Re: New to Board/New Build: PM30-MV Mill, Acorn, CNC12 pro, DMM DYN4 & .75KW SERVO X/Y/Z, DMM SERVO SPINDLE !!
AT_cnc wrote: Tue Jul 24, 2018 10:17 am The Z-axis is indeed Dove-Tail on the PM-30MV, based on the PDF. Attached.
I will follow up with DMM as you mentioned.
Link to PM30 Z-Axis
https://drive.google.com/open?id=1XdQsU ... TzN0CZOvRW
You don't need the brake. The friction of the Dovetail ways will hold the head.
AT_cnc
Post by AT_cnc »
Thanks Marty.
AT_cnc
Post by AT_cnc »
I did follow up with both Precision Matthews and DMM. I want to share my finding for the benefit of the community.
Matt at PM did confirm that there is nothing that prevent the z-azix from dropping other than friction from the dovetails.
DMM indicated that the brake is controlled independently by the servo drive (DYN4). The Acorn has no interface with the brake. It will need an external 24VDC power supply and 24VDC relay to control the brake. Please see attached wiring diagram from DMM.
https://drive.google.com/open?id=1HNxXb ... 6JJYfIF4AY
Certainly your call on how you want to set up your Z axis. You want a brake, wire it up.
It seems the DYN4 drive will close the brake circuit when it is not holding the servo.
I think you might find there is plenty of friction on the dovetails that the head isn't just going to drop.
Try it move it up and down by hand, not coupled to a servo motor or a rack.
AT_cnc
Post by AT_cnc »
So I finally received my PM30-MV after 4 months wait. Since everything I will be doing with the PM30 cnc conversion is new to me, I decided to also start a YouTube chanel. I just posted my first PM30 video. It is about unpacking and walk-around mainly. Link is below.
I have already took apart the machine, completely. I remove all electrical wiring and control panel, since I will run a new DMM servo and control from the acorn software. I will post links to the PM30 tear down as I post them on YouTube.
https://youtu.be/xw0XL2lz9qQ
