Page 2 of 2
Re: Help with Fuling VFD < resolved>
Posted: Fri Nov 01, 2019 2:04 pm
This is a Centroid Acorn support forum, not one for Chinese VFDs 8-)
Can you get support for the Fueling VFD from its manufacturer?
Suggest you buy GS1 or GS2 from Automation Direct.com or one of Factorymation.com TD series drives.
All that said, I will take a stab at what you need based on READING the manual.
Did you read the VERY first post on this thread?
DCM=Common for Inputs (Wire to Acorn Relay FWD COM, and Acorn Relay REV COM)
FWD=Spindle Forward. (Wire to Acorn Relay FWD NO)
REV=Spindle Reverse. (Wire to Acorn Relay REV NO)
RST=Drive Reset (Wire to Acorn Relay assigned to Drive Reset)
C=Multifunction Output Common. (Wire to Acorn COM)
A=Multifunction Output NO
B=Multifunction Output NC (You will have to see which one is closed when the drive is in a normal state. By checking continuity between C and A, C and B. Whichever shows continuity when the drive is on and in no fault state, wire this output to an Acorn Input. Assign the input to SpindleOK)
VI=VFD Analog Signal input (Wire to Acorn Spindle Analog output +)
ACM=VFD Analog Signal COM (Wire to Acorn Spindle Analog output COM)
NO CONNECTION TO VFD 10V! DO NOT CONNECT THIS TO ACORN OR YOU MAY DAMAGE THE ACORN SPINDLE ANALOG OUTPUT
PARAMETER SETTINGS
Set:
00=0001(Command frequency input determined by the analog signal)
01=0001 (Operating instructions determined by the external terminal connections) keypad STOP key effective
45=0009 (Multifunction output FAULT)
Did you watch my video on setting up an Automation Direct GS1 and benchtesting it before connecting to Acorn? I suggest you do, and you bench test the drive with jumpers and a battery BEFORE connecting it to Acorn!
These are just my best guesses. You still have to setup Accel/Decel, Lower/Upper Frequency limits, and any basic motor parameter settings (Volts, Amps, HZ etc)
Posted: Sun Nov 03, 2019 1:38 pm
by SocietyWC
Alright Thanks for the advice... as soon as the machine arrived and we opened the crate, I realized I got taken advantage of... Making the best of situation.
Posted: Sun Nov 03, 2019 4:17 pm
What do you mean? (Curious)
Posted: Sun Nov 03, 2019 7:43 pm
by bmilam
If you are still having problems getting it to run with Acorn, look thru your manual and see if it has a jumper that you need to switch. There are 3 small pins almost hidden and they have a jumper on them. If you have this then you need to switch the jumper to the other 2 pins to change from VFD to keyboard to operate it.
I had a similar problem and it was easily overlooked in the manual and took me a while to figure it out.
Posted: Sun Nov 03, 2019 8:40 pm
by SocietyWC
Thanks it sounds like your both right - There was a video some where with jumper added... I'll go through Marty's solutions tomorrow as well.
Looked for some time for a machine- 2 therm woods... + online... anyway I had bought what I thought was a mid range small machine assembled in the US. Needless I'm on my 3rd week of remanufacturing it.
So far the run out is coming to .001 for trueness with the back lash adjustment. Will have to retest once we start running it. Just got Park working which is amazing.
It may need support structure added to the gantry and the Z rebuilt. Once the motors running we'll start testing
See where its at
Cheers
Kevin
