Problems with Pawn Program <solved>
- CNC Control System Serial Number: C8FD19C4AB3B-0216180687
Re: Problems with Pawn Program
Thanks Gary. What your're doing is exactly what I want to do. The only difference is I edited the PAWN file to use T2. So, I only have T2 setup. Did you look at my procedure for setting up T2? I will setup T1 later today and give it a try. Not sure that would make a difference.
No I did not. No matter what I thought I saw, your testing it with an aircut would be the best insurance.
Re: Problems with Pawn Program <solved>
FIXED. I uninstalled the software and reinstalled it, setup T01 and all works as expected. I hope this can help someone in the future if they have this problem. What happened with the software I don't know.
I want to thank all who read and contributed to this problem. Hopefully, in the futrue I can contribute to this form in a positive way. Thanks again.
