Oak board and Leadshine easy servo
DannyB
CNC Control System Serial Number: A900712
Re: Oak board and Leadshine easy servo
Post by DannyB »
cnckeith wrote: Tue Apr 10, 2018 11:46 am should work, you'll need the Oak flying lead cable and you'll have to solder up the matching mitsu connector on the other end.
you can also run those mitsu drives with Acorn.
Thanks. I have breakouts that i test with and should work well enough to get it working before i solder.
I'm avoiding acorn because i have some needs for the closed loop functionality and encoder ports (and also have a >8 inputs and outputs right now)
