Dave_C wrote: ↑Fri Feb 16, 2018 10:47 pm
Ok, Looking at the picture there is no Limit switch connections to this drive but there is a USB port. Having used similar leadshine drives I have connected the special cable and checked to see how the drive was programmed.
I went to this site and looked up your controller.
If switch 1 is set to "ON" the motor will only turn clockwise!
Set switch 1 to "off" for Pulse and direction.
Dave C.
Hello. Dave C.
I really appreciate the help here.
I would like to call you personally to a different problem where you may help point out something I am overlooking again. Here is the thread viewtopic.php?f=20&t=1542.
Thank you in advance.
