Rigid Tapping parameter 78 ?
Re: Rigid Tapping parameter 78 ?
I'll look into it. You should not be receiving that message as your report indicates you definitely have Pro.
I apologize for the inconvenience.
- CNC Control System Serial Number: 38D26950ABAB-1221170383
I haven't connected my computer to the internet since before I started using the software. Perhaps this is an issue ?diycncscott wrote: ↑Thu Feb 15, 2018 7:37 am I'll look into it. You should not be receiving that message as your report indicates you definitely have Pro.
Jake
No it isn't. Please pm me with your email
Perhaps I can narrow the error down to one of the parameters changes tonight. Previously I had tried rigid tapping but only changing , I believe, 78 and maybe perhaps 36 too, I don't recall, but I didn't see the error until I made further changes to the many parameters suggested in the draft document ? The draft document for rigid tapping suggests changing parameters 36,37,68,69,74,78,82,84,240,241,149. So through trial and error I can go through those to put them back to their original settings which I should have from a previous report file.diycncscott wrote: ↑Thu Feb 15, 2018 7:37 am I'll look into it. You should not be receiving that message as your report indicates you definitely have Pro.
Jake
Did you send Scott a PM (private message) with your email address?cut2cut wrote: ↑Thu Feb 15, 2018 4:57 pmPerhaps I can narrow the error down to one of the parameters changes tonight. Previously I had tried rigid tapping but only changing , I believe, 78 and maybe perhaps 36 too, I don't recall, but I didn't see the error until I made further changes to the many parameters suggested in the draft document ? The draft document for rigid tapping suggests changing parameters 36,37,68,69,74,78,82,84,240,241,149. So through trial and error I can go through those to put them back to their original settings which I should have from a previous report file.diycncscott wrote: ↑Thu Feb 15, 2018 7:37 am I'll look into it. You should not be receiving that message as your report indicates you definitely have Pro.
Jake
Click on his name and it should take you to that window.
[/quote]
[/quote]
Yes, thanks Marty. I have. Perhaps he will figure it out before I try the above. I was just giving more details to work with. So far I haven't received an email.. he is probably looking for a solution, still.
Best Regards,
Jake
[/quote]
Best Regards,
Jake
[/quote]
Best Regards,
Jake
[/quote]
Scott starts super early and leaves early. You may hear from him tomorrow. He is worth being patient and waiting for direction from.
[/quote]
Thanks for the heads-up regarding his schedule . btw, I believe he asked for my email so he could fix a different issue I was having with my account here on the forum. I had asked a moderator and now notifications are working properly since I sent the email address.
Jake
- CNC Control System Serial Number: MILL 38D2693D0B0-0110180508 LATHE 38D2694DA013-0321180756
Hi there.
I have exactly same issue. Does anybody know how to get it sorted?
Working on it. Send me a pm with email.
