Page 2 of 3
Re: Spindle motor reversing relay/contactor
Posted: Fri Jan 05, 2018 12:01 pm
by DICKEYBIRD
Hey Scot, I just found a deal on a KBCC125R on ebay for my mill project: https://www.ebay.com/itm/KB-Electronics ... Swj85YN329 It's $55 + $30 shipping Buy Now/Make offer out of Canada. I offered $35.00 & it came back accepted pretty quickly so he'll probably take $30.00. It's from a batch of pre-owned industrial machine pulls. They're tested & have a guarantee. If you're still thinking about going the KB way, it may be a deal for you. :D
Posted: Fri Jan 05, 2018 1:47 pm
by ScotY
Thanks, Milton. I actually saw that but was a little skeptical because it sounded like such a good deal. Put in an offer and waiting to hear back.
Posted: Sun Jan 07, 2018 8:19 pm
by ScotY
Hi Milton,
Do you know what the purpose of the horsepower resistor is? I’m hoping the eBay controller has one that will work for my motor.
Posted: Sun Jan 07, 2018 8:34 pm
by frijoli
ScotY wrote: Sun Jan 07, 2018 8:19 pm Hi Milton,
Basically a current limiter. If you put a "1hp" resistor in and stall a "1/8hp" motor you will be surprised at the smell. lol
The flip side will not allow the motor full power.
Clay
Posted: Sun Jan 07, 2018 8:40 pm
by DICKEYBIRD
Yep, it matches the max output of the drive to the max input of the motor. Marty may correct my understanding of it but IMO if the resistor is in the ballpark, it'll work fine. I forget, what's the wattage on you motor, 500 watts? If so, a 3/4 hp resistor's what you want. OMG, if you put on a 1 hp you'll black out the entire pacific area! (Just kiddin', unless it's WAY too small it'll be fine.) :D
Posted: Sun Jan 07, 2018 11:00 pm
by ScotY
Thanks for the info, guys. Hopefully, it comes with some sort of suitable resistor. I would think it might since it was operational at one point. My project list is getting really long again!
Posted: Tue Jan 09, 2018 2:44 pm
by ScotY
I've been reading the manuals for the KBDD-125R and KBSI-240D. I think I understand how it's supposed to be wired up to the Acorn. S1, S2 and S3 will be switched with the Acorn's onboard relays for forward/reverse control. P2 and F- will be supplied 0-10vdc through the KBSI-240D for rpm control. What I'm not too sure of is the forward/reverse operation works. The manual seems to indicate the control will decelerate/brake/accelerate the motor in the opposite direction by immediately swapping the connection to S2. Yet, for a manual rotation change, they suggest a on-off-on type switch. And they also talk about an anti-plug reversing feature...what the heck does that mean? :shock:
Posted: Tue Jan 09, 2018 5:13 pm
by DICKEYBIRD
I think term "anti-plug" means that it prevents the harmful effects of simply reversing the (DC) plug while the motor is still spinning in the other direction. Kinda like shifting your car into reverse while it's still moving down the road. :shock:
As far as the manual switch question I think that refers to being able to switch from automatic (Acorn 0-10v control) to manual (5K pot) control of spindle speed. I have an automatic/manual switch on my ORAC.
By the way I got my 2nd KBCC-125R yesterday & it looks good. Yes, it came with a 1/2 hp resistor. I couldn't believe it when showed up before noon....from Canada. I ordered it Fri afternoon! :o
I hope to install it in the mill's control box this weekend and will attempt to do a schematic. Unit #1 on the ORAC works perfectly but as usual, I didn't draw a diagram when it was set it up with the C-11/Mach3 a few years ago. When I switched over to Acorn, I had fits connecting the unmarked wiring. :oops: I'll try to do better this time.
Posted: Tue Jan 09, 2018 6:44 pm
by ScotY
Thanks, Milton. Mine came in yesterday, as well. It’s quite a large piece of gear! :shock:
Posted: Tue Jan 09, 2018 7:46 pm
by DICKEYBIRD
ScotY wrote: Tue Jan 09, 2018 6:44 pmIt’s quite a large piece of gear! :shock:
Manly work requires manly tools. These were designed back when ships were wood & men were iron! :D
ps: I picked up an electrical box big enough to hold it at Home Despot & mounted on the back of my ORAC.
