Yes, that is the wrong type of encoder. You need one with differential output signals (two wires per channel, not just one wire per channel).
That is why you could not find anything to connect to pins 3, 4 and 5 of the DE9 connector. Pins 3, 4 and 5 receive the complementary signals: /Z, /A and /B (also called Z-not, A-not and B-not, or other variations of the same idea).
I would guess that you also had to defeat the "412 ... encoder differential error" alarm somehow, unless that is always defeated for Acorn controls.
How do I troubleshoot bad threads? <Resolved>
Re: How do I troubleshoot bad threads?
- CNC Control System Serial Number: 0479B7ADF2F3-1127192707
Thank you!
I’ll find the right encoder.
Mike
Mike
Would this encoder work?
https://www.automationdirect.com/adc/sh ... d-sr2000vd
Yes.Would this encoder work?
Thanks! I ordered it. I’ll follow up with results.
1 user liked this post
The proper encoder works great!
Thanks for the help!
Mike
Mike
3 users liked this post
- CNC Control System Serial Number: 6665
Re: How do I troubleshoot bad threads? <Resolved>
fusion,
Absolutely bee-U-ti-Ful! I am not joking. Those threads are gorgeous. Anyway, enough oohs and drool over here. Good thread work!
Seth
Seth
