Page 2 of 2
Re: Z-Axis Doesn’t Retract After Probing – Can’t Move Axis
Posted: Mon Apr 21, 2025 4:57 pm
by ShawnM
madixCnc wrote: ↑Sat Apr 19, 2025 4:07 am
Strangely, when I configure the TT as a touch plate, it performs a retract after probing.
Yup, because it should be configured as a touch plate since it's movable.
Posted: Wed Apr 23, 2025 12:24 am
by suntravel
You can set P547 to a bigger value than 1.27 for more retract height.
Posted: Wed Apr 23, 2025 11:25 am
by ShawnM
And yes as noted by others, with any spring loaded touch plate or tool touch off you need to configure the retract height correctly so the input changes state during this very small retract distance. If the input doesn't change state then it'll stop motion.
Probes are setup differently.
