452 Ethernet Communication Error, (AvidCNC EX controller) <resolved, dust collection static not drained>
Re: 452 Ethernet Communication Error, (AvidCNC EX controller)
cobymcconnell wrote: Fri Mar 14, 2025 1:38 pm Problem Solved: It was the static charge that the dust collection was creating. I disconnected the hose, and that took care of it.
I'll ground the dust collector and the body of the CNC, and it should be good . Thanks for all your help.
It actually wont be good as the static buildup is in the hose itself.
Best option for a dust collector is metal duct from the dust collector to directly above the table. All this is now grounded to the dust collector. Then your flex hose can run down to the machine. You can even run a bare copper wire inside the flex hose for additional ground or buy the anti-static flex hose. Dust collection can be a "noise nightmare".
Our setup runs 8" metal duct from the cyclone vac to the center of the table then turns down 90° via two 45° elbows to a 4" reducer 4" for the anti-static flex hose from Dust-Right.
