mpg hand wheels <Resolved>
- Hickory CNC Controller: Yes
Re: mpg hand wheels
Spoke too soon, now the wireless hand wheel is not working.
Re: mpg hand wheels
Please post a new report. We should be able to figure out what is going on from the parameters and any PLC modifications.
Re: mpg hand wheels
Report from this morning attached. Thanks.
- report_0008DC111213-0420231461_2025-03-17_09-22-30.zip
- (7.69 MiB) Downloaded 5 times
Re: mpg hand wheels
Oak and ALLIN1DC stock PLCs are not set up to work with both WMPG and other handwheels by default. The Acorn, AcornSix, and Hickory Wizard PLCs are set up to allow the hardwired MPGs to work when the WMPG is disabled and vice versa.
Try replacing this block in your PLC program
with the following.
This should disable the two wired MPGs while the WMPG is enabled and allow their use when the WMPG is disabled.
; Enable the Software to read the Wireless MPG or Hardwired MPGs with MPGLED
IF (MPGLED_O && HandWheel_M && !MPG_M) || UsbMpgOn_M THEN (SV_MPG_1_ENABLED)
IF MPGLED_O && SV_MPG_2_AXIS_SELECT > 0 THEN (SV_MPG_2_ENABLED)
IF MPGLED_O && SV_MPG_3_AXIS_SELECT > 0 THEN (SV_MPG_3_ENABLED)
IF MPGLED_O && SV_MPG_2_AXIS_SELECT > 0 && !UsbMpgOn_M THEN (SV_MPG_2_ENABLED)
IF MPGLED_O && SV_MPG_3_AXIS_SELECT > 0 && !UsbMpgOn_M THEN (SV_MPG_3_ENABLED)
1 user liked this post
Re: mpg hand wheels
Perfect! Works great, thanks again for your support!
Re: mpg hand wheels
Happy to help! Let us know if you have any further questions!
