Ok, so now I'm really confused. I went out today and repeated what I did yesterday, and everything works as it should. Didn't do anything different. I turned everything off and on a few times, and it worked properly each time. I'm at a loss - I don't like it when things fix themselves and I don't know why. If you learn anything when you investigate, please let me know what I might have or have not done to make this happen.
I did notice that everytime you select a different option in Homing in the wizard, the homing direction for Y axis changes back to M92, and I need M91.
Also, wondering where the macro is for the spindle warmup button in the VCP? I'd like to change it a bit if possible.
Prevent HOM file overwrite in v5.24 wizard
- CNC Control System Serial Number: haven't installed CNC12 yet
Re: Prevent HOM file overwrite in v5.24 wizard
c:\cncm\system\perform_spindle_warmup.cnc
edit at will.
edit at will.
