Umbrella ATC - Acorn Compatible
Re: Umbrella ATC - Acorn Compatible
no problem i have done that, just make a loop and strain relive it so you can open and close the door.
i've also crammed an e1616 on the cabinet side.
RJS100
Post by RJS100 »
Thank you.
Since you have powered components mounted to the door, you should install a bonding (grounding) jumper wire from the main cabinet or panel to the door. In the trade, we don't trust the hinge pins to provide a safe path to ground.
RJS100
Post by RJS100 »
Will do. Thanks.
RJS100
Post by RJS100 »
Linear Rail Question:
These ATC plans call for SBR16-350 rails and SBR16 slide blocks. Is SBR a brand? I could only find these on Amazon and Aliexpress. I want to make sure these are good enough slides or if should be looking at something else? I have no experience with linear slides.
RJS100
Post by RJS100 »
Thanks! What is the advantage of the HGR20?
Better precision with less play.
RJS100
Post by RJS100 »
Thanks Uwe. Here is a video where someone used HGH15/HGR15 assembly.
At the four-minute mark he points out a problem with getting lubrication to both units. Not sure I am crazy about his solution. Let me know what you think.
Also, here is what I am working on for a sensor. It is based on the ideas that Marc from CNCSNW suggested. Marc suggested that the sensor trigger when the carousel is locked.
https://www.dropbox.com/scl/fi/26nos4lo ... n1qvl&dl=0
Thanks... Richard
On an ATC in hobby use it will take a very long time till it needs to be greased again.
