Page 2 of 2
Re: Special Machine four axis
Posted: Fri Nov 22, 2024 10:37 am
by Nigelo
Sorry just noticed my reply above may not be what you need as you are trying to run a sub-Prog nn times within a single run of your master prog
Posted: Sat Nov 23, 2024 4:36 pm
by Ron B.
I have completed my version of my VCP but have one error.
I changed the X axis jog buttons size and location. They look good on the screen.
But when I press X+ I get a Y+ movement same goes with the X- jog button I get a Y- movement.
All other axis move correctly. I did change to X_positive_front_mount, X_negative_front_mount style of button.
Everything work just fine before that.
I switched back to X_postive x_negative how the code was before and I'm good again. But my arrow is pointing the wrong way.
What did I miss?
Posted: Wed Nov 27, 2024 5:22 pm
by Centroid_Jacob
Hi Ron, can you post a fresh report.zip file please so we can take a look at your VCP?
Posted: Wed Nov 27, 2024 5:29 pm
by cncsnw
Are you using Mill software (where X is axis #1), but using lathe VCP buttons?
On a lathe, the X axis is axis #2, so lathe buttons like "X_positive_front_mount" and "X_negative_front_mount" use skin event numbers for axis #2 jogging.
You can edit the button XML files to change the "skin_event_num" field to use axis #1 jogging command numbers (37 for minus, 39 for plus).
Posted: Fri Nov 29, 2024 10:52 am
by Ron B.
"You can edit the button XML files to change the "skin_event_num" field to use axis #1 jogging command numbers (37 for minus, 39 for plus)."
I leaned something new!
This did the trick thank you!
