silver2row I had no issues with the 24v optical sensors on my current controller board. I just had to use the resistor the designer specified and I was good.
When you said "I have not added the laser, i.e. as the support for the controller of the laser is officially gone" I'm assuming that was laser manufacturer not Centroid/Acorn that wasn't supporting it?
I'm a little confused as well where it comes to my Clearpath servo connections. The thread on adding this servo to an Acorn talks about two different BOBs needed to use the error reporting connection from the servos and also to make them plug and play using another board. If I went with the AcornSix would I need those additional boards? I already made connectors to connect from the servo factor cables to my machine cabinet outside and then from there each wire connects to mu current board.
Onawa220 wrote: ↑Tue Oct 22, 2024 2:58 pm
no.
see the AcornSix to Clearpath connection schematic on the schematic page.
My order arrived today and now that I'm about to disconnect everything from the other control board I'm having doubts on what I'm needing to do for the Clearpath servo connections. For a board that can control 6 servos why are so many inputs being combined????? I've gone through 3 different control boards in my 10 years and each one had a separate input for each stepper or servo so this kind of blows my mind.
If I'm reading the drawing right I am combining a lot of wires to go into one connection on the AcornSix. It looks like I combine Enable-, Input A-, Input B- and HLDB- and connect them to the pin marked GND on Connector H14?
Then I'm connecting 3 Enable+?
