Hi there, thanks for that. I had changed the inputs as suggested and it the wizard noted that I cannot have a limit_all under input 7. Been trying to figure out the wiring for the machine. Will go and read the manual again and try and trace the wiring for input 7. Does not seem to go to the limits. In case it helps, the report file from the machine is attached as well. Thanks for all the help. CheersShawnM wrote: ↑Wed Sep 25, 2024 12:46 pmPlease reread the post from Centroid, Your inputs are not setup they way they suggested. You need "FirstAxisHomeLimitOk", etc. Your's are just set as home switches and not home/limit switches.jamac wrote: ↑Wed Sep 25, 2024 12:36 pmThanks for your help here. Have had a look and the machine is set up as follows.centroid467 wrote: ↑Mon Sep 23, 2024 9:27 am In the Wizard, try the "Input Definitions" page and change the switch input assignments depending on the configuration:To say exactly what you need to do, we will need a new report from the machine.
- to "HomeLimitAll" if they all go to one input
- to "FirstAxisHomeLimitOk", ..., "ThirdAxisHomeLimitOk" if all switches for a specific axis go to a single input
- if each switch has its own input, then assign "{First/Second/Third/Fourth}AxisHomeLimitOk" to the switch that will set home and the appropriate version of "{First/Second/Third/Fourth}Axis{Plus/Minus}LimitOk" to the other switch on the axis.
Will post a report from the machine as well.
407 limit issues <basic cnc configuration >
- CNC Control System Serial Number: 74E1825CECEB-1217181455
Re: 407 limit issues
- report_74E1825CECEB-1217181455_2024-05-11_05-43-44.zip
- (823.26 KiB) Downloaded 4 times
Thanks for the report. Several issues to note first, you are using 4.8 which is very old, with known bugs, and no longer supported. You should install the latest version which is 5.1 for free support.
Please post a CURRENT report from today or maybe from the last week if you have one. The report you uploaded is over 4 months old.
Remove the "limit all" from input 7. It's not needed right now and really not at all. You can set up "soft limits" in the Wizard for your max travel. No switches or wiring needed.
Set inputs 1,2 and 3 correctly because they are still incorrect in this report. If you've changed anything you should upload a CURRENT report for better help.
Your "steps per revolution" settings in the wizard are incorrect. They can never be 17,143 or 18,751 like they are now, they are simply wrong. Those values are either 1600, 3200, 4000, 6400 or even 8000, etc. They will ALWAYS be a whole number. It can never be the value you have it set at. This value MUST also match the settings in the drive. What servo/stepper drives are on the machine? Please start a Google album and share the link here. Take a bunch of pics of the control cabinet, drives and limit switches so we can see what you are working with.
You MUST correct the drive setup problems before you go any further. Set the steps per revolution correctly and the drives to match. Then you can proceed. A software updsate is recommended but if you choose to stay with 4.8 you'll have known issues.
1 user liked this post
Shawn. Thank you for the reply. Will go and digest this. Apologies for delay getting back to the post, have been travelling. The report was only a few days old. Will check pc as suspect date setting are out (not connected to internet).
A lot to unpack here but will start with an update and setting as limit and home and see where this takes me.
Happy new year all.
So I have spent some time over the festive period rebuilding controller pc from fresh. New install to latest version and going through steps one at a time to understand what is going on with the help of the notes already passed here.
Have all limits now wired normally closed.
Setting up axis and getting head round stepper counts.
The drives and panasonic ac motors and controllers all set to 10k steps per revolution (verified in the driver parameters).
For the x and y axis I have a ratio of 24/14 (== 1.7143) teeth between small drive shaft and leadscrew shaft on my bridgeport. Leadscrew has a travel of 5mm per rev. Have entered the 10k pulses per turn and the ratio of 1.7143/5 to get number of turns on drive motor to give 1mm travel on x axis. Hopefully have this right. Struggled with the mm/turn on the wizard. Think this means mm/turn of the motor not the leadscrew… otherwise no connection of ration between the two.
Max pulse frequency set to 200khz which driver can easily handle.
Now looking to enter jog min/max rates and get the following error. Any ideas as the 200khz and 10k pulses per rev should let me spin the motor at 200 revs per second!
Many thanks
John
Many thanks
John
200.000 / 10.000 = 20 not 200
Haha of course thanks.
Do I have ny ratios right? Gone round the houses a few times in my head on it. Cheers
with 24 on the motor and 14 on the spindle: 24/14x5=8.5714 mm travel for one rpm of the motor
Hi Uwe. Its the other way round. Motor is the smaller of the two. Cheers
mm / turn in the Wizard is indeed the distance travelled for a single rotation of the motor. So, this includes all reduction from gearing or belts to the pitch of the screws/rack/etc.jamac wrote: ↑Fri Jan 03, 2025 11:58 am For the x and y axis I have a ratio of 24/14 (== 1.7143) teeth between small drive shaft and leadscrew shaft on my bridgeport. Leadscrew has a travel of 5mm per rev. Have entered the 10k pulses per turn and the ratio of 1.7143/5 to get number of turns on drive motor to give 1mm travel on x axis. Hopefully have this right. Struggled with the mm/turn on the wizard. Think this means mm/turn of the motor not the leadscrew… otherwise no connection of ration between the two.
Many thanks
John
That's one reason we always ask for pictures
Then you'd be looking at 2.9167 mm / rev for a starting value. That gives an absolute max rate of 20 rev/second * 2.9167 mm / rev * 60 second / minute = 3500 mm/minute.
Fab thanks. Of course picture vs many many words. Apologies. So the turns ratio is the travel a single turn of the motor shaft provides. That makes sense. The single inch examples threw and thought I was looking for turns per inch or mm of travel rather than travel a single turn produces.centroid467 wrote: ↑Fri Jan 03, 2025 1:13 pmmm / turn in the Wizard is indeed the distance travelled for a single rotation of the motor. So, this includes all reduction from gearing or belts to the pitch of the screws/rack/etc.jamac wrote: ↑Fri Jan 03, 2025 11:58 am For the x and y axis I have a ratio of 24/14 (== 1.7143) teeth between small drive shaft and leadscrew shaft on my bridgeport. Leadscrew has a travel of 5mm per rev. Have entered the 10k pulses per turn and the ratio of 1.7143/5 to get number of turns on drive motor to give 1mm travel on x axis. Hopefully have this right. Struggled with the mm/turn on the wizard. Think this means mm/turn of the motor not the leadscrew… otherwise no connection of ration between the two.
Many thanks
John
That's one reason we always ask for pictures![]()
Really appreciate the help. Cheers
