I recognized the tracking adjustment instantly having built numerous belt grinders. It looks like a very well thought out grinder. Did you design it?
Re: 1/2 - 13 TAP - 6061 Aluminum (Rigid Tapping)
Posted: Thu Aug 29, 2024 6:54 pm
by suntravel
and of course we want to see the finished grinder
Posted: Fri Aug 30, 2024 12:13 am
by RJS100
Yes. Pictures for sure when it is finished. I certainly cannot take credit for the design. It was designed by James Clough (YouTube Channel Clough42). It was designed with the intention of sending the parts out to someone like SendCutSend to water cut, plasma cut and bend most of the parts. Full link to YouTube below.
This is my first actual CNC project. I am slowly redesigning as many parts as possible so they can be made on my converted mill or lathe. I in no rush, so I just keep chugging away. All the parts in the images below that are Titanium Nitride colored, are the parts that I redesigned.
Best... Richard
Posted: Fri Aug 30, 2024 1:53 am
by suntravel
The plate holder needs to be adjustable, so you can use bolt on plates with different thickness.
Beltgrinders made from non Knifemakers are often not really well designed..
Maybe you can pick up something for your redesign.
Posted: Fri Aug 30, 2024 3:20 am
by Black Forest
That is a lot of work on the CNC mill to make your grinder. Uwe is talking about the platten behind the belt. It needs to be adjustable in and out to accommodate different plattens. I use a soft platten sometimes on mine and a curved platten.
Posted: Mon Sep 02, 2024 12:30 am
by RJS100
Yes, you are correct, it is a lot of work but I am doing it primarily to learn how to machine parts. I took the Titans Of CNC online CAM course, now I am trying to make stuff! The more I make, the more I learn. I was very fortunate to retire early, so this keeps me quite busy.
Thanks for the clarification. I don't think the previous images showed the platen very well. Here is a better image. It is definitely adjustable.
Thanks for your thoughts... Richard
Posted: Mon Sep 02, 2024 12:35 am
by RJS100
Uwe, thanks for sharing the belt grinder design. Very well done! I will surely take a few ideas from it.
Posted: Fri Sep 13, 2024 3:22 am
by cnc king
It should work
Posted: Sun Jan 12, 2025 11:36 pm
by RJS100
Ok... Here are the pictures you requested. THANKS FOR ALL YOUR HELP! Really appreciated!
Posted: Tue Jan 14, 2025 2:21 am
by ThomasRoan
In theory, it should be fine, but if you're unsure, it's best to conduct some tests first to ensure the feasibility and effectiveness of rigid tapping.
