Thank you for the advice. I am stuck on these fans, as the adhesive fits near perfect in between the two heatsinks. One heat sink is on the driver and the other heatsink is on the dual, 5v fans which then receive the cooling.
I think I have some other fans around here somewhere. I will look around. I just do not know right now if I have them in stock.
Seth
P.S. Richards and ShawnM, I appreciate the feedback. (I think these are 5v fans). They are not listed as having any PSU dedication. So, they may as well be 5v, 12v, and/or 24v without my knowledge. I will keep searching for a unit fan too. The box will need cooling as most electronics get a bit hot when being powered and used.
Simple (Hopefully) 5v Question for Fan Usage on the Acorn CNC
- CNC Control System Serial Number: 6665
Re: Simple (Hopefully) 5v Question for Fan Usage on the Acorn CNC
