Re: Getting "DRIVE FAULT" when trying to bench run...
Posted: Sun Aug 18, 2024 4:04 pm
The forum software screwed with the link. Add "i." in front of the hostname and it should work. when I edited the post, the correct URL for the image was shown. Not sure why it's getting messed with.Sword wrote: ↑Sun Aug 18, 2024 3:02 pm Imgur link doesn't work, and it's hard to tell by zooming in on it here, but something doesn't look right with that E-Stop circuit. Are there two black wires going into input #1? It looks like IN1 and IN8 are looped together and to common. Really hard to see for sure.
Also, verify that the 6 encoder wires are in the correct order. Do you get a flash code from the driver?
The E-stop is wired exactly as shown in the schematic. One side of the switch goes to IN8, the other side is tied to IN2 and COM. (gnd)
Hitting the E-stop results in an e-stop message in CNC12. This was tested before I started connecting the driver.
The encoder wires are correct based on the 'D1008 user manual - the driver cables were built by Leadshine.
No flash code from the driver - it only shows the green Power LED.
g.
