Thanks, I saw your note about not using a TIN coating and realized earlier in the post, I linked to the wrong tooling. That taps I purchased have a TiCN coating. Thanks for your thoughts. In the future I will try the forming taps.
Tap I purchased: https://www.suncoasttools.com/crm/ItemP ... er=YG1TOOL
New Rigid Tapping Question
Re: New Rigid Tapping Question
When encountering resistance while tapping into 1018 cold-rolled steel, try adjustments such as increasing the speed, using lubricant, gradually increasing the depth, etc., to complete the tapping process smoothly.Regarding other matters, there are too many words to type out, please refer to this:https://www.want.net/choosing-the-right ... rocessing/
"When testing M5 tap on 1018 cold-rolled steel at a depth of 0.6 inches, encountering resistance, it is recommended to try increasing lubrication, reducing tapping speed, pre-drilling appropriately, checking tap quality, and controlling depth to address the issue."
Regarding the different feed rates for chamfer bits made of various materials, it is recommended to refer to:https://www.want.net/comparing-tungsten ... echnology/
