encoder suitability
Re: encoder suitability
The spec sheet on that encoder does not give the signal type. You need a differential quadrature encoder, typically listed as A, A/, B, B/, Z, Z/ (sometimes the 3rd channel is listed as I, I/ but its the same thing).
Please see this thread for a detailed explanation:
viewtopic.php?f=60&t=921
this pdf covers the entire E6B2-C Omron line up, they make different versions of this model.. some of the models would not work and some would.
the type of encoder you want is a , 5 volt TTL encoder with A/A- , B/B- and Z/Z- channel, Incremental Quadrature Differential Encoder, 2000 Line (ppr) (or higher). that would be the E6B2-CWZ1X 2000 P/R model on this PDF.
thanks Keith, exactly what I was after..
cheers
cheers
E6B2-CWZ6C IS NOT COMPATIBLE
E6B2-CWZ1X may be, because it has the required LINE DRIVER OUTPUT. I have not tested it. So I will not say it will work for sure. (though I just ordered one from CHINA to test but yup, shipping might take several weeks) http://r.ebay.com/OpwkLX
Cut sheet for the 2000 line line driver encoder: https://www.ia.omron.com/product/item/2391/
The Encoder must be INCREMENTAL LINE DRIVER OUTPUT.
Guys, if you don't read and follow the encoder requirements, for the sake of saving a BUCK, you may either be disappointed that you wasted your money OR you may damage Acorn. $265 in the toilet to save $50....
You have a real Industrial controller, with a REAL industrial Encoder port on it, that requires a REAL encoder.
Last edited by martyscncgarage on Fri Oct 13, 2017 11:31 am, edited 2 times in total.
E6B2-CWZ6C is NOT compatible it has an NPN output NOT a Line Driver Output
Here is the comparison chart: http://www.mouser.com/ds/2/307/e6b2-c_d ... 597308.pdf
See output configuration on page 2.
good call marty, i've ordered one too, when you say you could fry the acorn, is there a way to test the enocoders suitability before connecting to acorn?
Did you order from the seller I did? When I asked about shipping and if the item was Genuine Omron, they emailed back and said sorry, we made a mistake and said they don't have any in stock.
Again, pennywise pound foolish, if too good to be true, it probably IS......I'll report back with what this other seller says.
Unless you are an experienced electronics bench technician with an Oscilloscope, no easy way to check it. You need to check the square wave signals from each channel, and there are 6 of them....
Chinese stuff is hit and miss. Bad habit of we hobbyists is being too thrifty, we are very stubborn!..."Cry once, buy once"
the seller i ordered from is called '"queen's land"
you got me thinking now, don't want to risk the acorn for saving a few quid
Go check see if the listing is still up. Message the seller and ask what happened. See how they respond....go back to my post above and that seller has sold a number of them....doesn't make them legitimate, but that they had them.
I'm going to try and get one...test it and report back...to save others the grief or question of whether or not the Chinese units will work. If these guys cancel me, I will report back and recommend users not purchase them from China.
Automationdirect.com OR Centroid are the go to sources for legitimate encoders. Keith aint gonn reguritate this information.
We just have to stop being stubborn and buy the real deal.....
yes the advert is still up and i've been given the usual 6 week delivery window! So how do i test it when /if it arrives?
