Hello.
I need my machine to brush a piece of metal.
So I need the machine for example 40" in Y direction back and forward...let say 10 times.
with a certain speed, spindle on at a certain rpm...no Z of X movements.
What would be the best way to do this?
I had done this in the past thru Vcarve but I needed to setup the Z to go lower very few inches.
This time the Z needs to be steady.
Thank you!
How would you do this line movement?
- Plasma CNC Controller: Yes
Re: How would you do this line movement?
hancoding
#101=0
N0010
G1 Y0 F10
G1 Y40
G1 Y0
#101=[#101+1]
IF #101 == 10 THEN GOTO 20
N0020
Or use Line / Repeat in Intercon
Both explained in the manual
#101=0
N0010
G1 Y0 F10
G1 Y40
G1 Y0
#101=[#101+1]
N0020
Second to last line should maybe read
IF #101 < 10 THEN GOTO 10
Sure, I forgot it
