Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
occustoms
Re: Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
Post by occustoms »
Here is error log.
Information: Configuration: CENTROID Milling Community 1.0
Information: Vendor: CENTROID
Information: Posting intermediate data to 'C:\Users\Cad Computer\Desktop\1001.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, April 22, 2025 7:13:43 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 5.245.0
Configuration path: C:/Users/Cad Computer/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/Centroid_Mill_Community_v1.0.cps
Security level: 1000
Include paths: C:/Users/Cad Computer/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Thursday, January 9, 2025 4:03:12 PM
Output path: C:\Users\Cad Computer\Desktop\1001.nc
Checksum of intermediate NC data: 5ed6fade358e4b01133b7d3dcf73a305
Checksum of configuration: f60260c71d2c6496ac8126f0f7c4014e
Vendor url: http://www.centroidcnc.com
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion CAM 2601.1.34
Warning: Work offset has not been specified. Using G54 as WCS.
Error: machineSimulation is not defined
Error at line: 2095 (Centroid_Mill_Community_v1.0.cps)
Error in operation: 'Multi-Axis Finishing1'
Failed while processing onRapid5D() for record 423.
Error: Failed to execute configuration.
Stop time: Tuesday, April 22, 2025 7:13:43 PM
Post processing failed.
You did not setup a machine for simulation with the kinematic of your machine
This post is using the kinematics from the simulation machine with more than 3 axis.
occustoms
Post by occustoms »
I get this error if i set up a machine for config just trying to simulate it in fusion.
Cannot simulate with machine:
Machine configuration is overridden by the post script.
at onOpen (Centroid_Mill_Community_v1.0.cps:468)
occustoms
Post by occustoms »
ok no matter what i put inside the machine configuration, i get an error just trying to simulate with the swissi original post processor and the community one.
here is the swissi original one error log.
at onOpen (Centroid_Mill_MinRev-40783-swissi-005.2 + Spikee machine sim mod + uwe peck tapping mod.cps:468)
 In-process stock is missing. Stock might be inaccurate
can you upload the fusion files, so I test it out?
occustoms
Post by occustoms »
yes. but 3 axis centroid post processor from fusion works with machine simulation. So it has to be something in both of these post processors.
Test part 4th axis.zip
(6.53 MiB) Downloaded 20 times
Should work now.
I have added Inverse time.
centroidForumV2.zip
(20.06 KiB) Downloaded 18 times
occustoms
Post by occustoms »
this same file download on page 1?
occustoms
Post by occustoms »
I get this error now when trying to simulate 4 axis.
Error: Section.getInitialToolAxisABC() is not allowed for section.
Error at line: 847 (Centroid_Mill_Community_v1.0.cps)
occustoms
Post by occustoms »
also get this when trying to post an opp.
Start time: Friday, April 25, 2025 6:16:01 PM
Configuration path: C:/Users/Cad Computer/AppData/Local/Autodesk/Autodesk Fusion 360/HXKFJYDRGFDW/W.login/M2/us-D20200828327366981/CAMPosts/Centroid_Mill_Community_v1.0.cps
Include paths: C:/Users/Cad Computer/AppData/Local/Autodesk/Autodesk Fusion 360/HXKFJYDRGFDW/W.login/M2/us-D20200828327366981/CAMPosts
Checksum of intermediate NC data: be40c86b8d89ffccad8cc76a6292d820
Failed while processing onRapid5D() for record 425.
Stop time: Friday, April 25, 2025 6:16:01 PM
