Software Fault Problem
- CNC Control System Serial Number: 98F07B91EF87-1007248634
Having a problem bench testing new Acorn controller.
Set up EStop button, operates fine.
Set up DriveOk on input 5, operated fine.
Removed DriveOK from input 5, Acorn operates fine.
Set up DriveOK on input 5 again, now have drive fault that won't clear with or without #5 input.
Remove DriveOK from input 5, acorn operates fine.
Repeat testing shows fault problem returns.
Did I error somewhere?
Noticed the fault messages were in the wrong order.
- report_98F07B91EF87-1007248634_2025-04-13_10-57-00.zip
- (1009.46 KiB) Downloaded 3 times
Re: Software Fault Problem
I thought bench test was to just get motors running and did't use fault lines. Get it moving with very basic wiring, and then add those in.
Post what wiring diagram you are using, what drivers, and put some pics in of how you wired it.
Ken
- Tech Support
Looking at your report I can of course see the drive faults, but you're also getting communication errors.
Above all else these need to be fixed first: viewtopic.php?t=1451
(1) 04-12-2025 20:00:43 199 CNC Started
(1) 04-12-2025 20:00:55 102 Error initializing CPU...cannot continue.
(1) 04-12-2025 20:00:58 201 Exiting CNC due to a known error (63)
(1) 04-12-2025 20:01:10 199 CNC Started
(1) 04-12-2025 20:01:17 CNC12 Acorn Router v5.20
(1) 04-12-2025 20:01:17 490 Reset Initiated, Press Reset to Clear
(4) 04-12-2025 20:01:29 9031 DRIVE FAULT!
(1) 04-12-2025 20:03:43 490 Reset Initiated, Press Reset to Clear
(1) 04-12-2025 20:03:46 490 Reset Initiated, Press Reset to Clear
(1) 04-12-2025 20:04:00 490 Reset Initiated, Press Reset to Clear
(4) 04-12-2025 20:05:02 9031 DRIVE FAULT!
(1) 04-12-2025 20:05:33 204 Exiting CNC...Normal Exit (66)
(1) 04-12-2025 20:09:56 199 CNC Started
(1) 04-12-2025 20:10:03 CNC12 Acorn Router v5.20
(1) 04-12-2025 20:10:03 490 Reset Initiated, Press Reset to Clear
(4) 04-12-2025 20:10:26 9031 DRIVE FAULT!
(4) 04-12-2025 20:11:01 944 MPU requested resend # 1
(4) 04-12-2025 20:11:01 945 PC requested resend # 1
(4) 04-12-2025 20:11:01 946 PC resending # 2
(1) 04-12-2025 20:19:59 204 Exiting CNC...Normal Exit (66)
I am not surprised about com errors, I definitely made some mistakes going through this.
I'll try doing several more tests and see if the com problem shows up again.
Drive Fault is not a software issue, if it comes without the driver in ALM mode the wiring or setup NO/NC of the driver / Acorn input is nok.
And COM errors are also not a software issue, it's a wiring issue. Not using shielded wire where it's needed and proper MTW for the machine. Could also be a grounding issue.
Ron
hello.
since you are just getting going this would be a good time to use the latest version of CNC12 so we are all on the same version and can help you best.
hello.
cnckeith,
I agree, will install latest version and post with new info.
