Hi There.
My Acorn V5.22 is crashing when I do a search to start from a particular line (N block).
System ran flawlessly on V4.82.
PC is Win10 with all windows updates and passed the PC tuner tests. (PC does not crash.)
Report and Intercon file I was running is attached. (Happens on any file so far).
Any advice would be appreciated
Bernard
Acorn V5.22 crashes when start from search N line < fixed>
- CNC Control System Serial Number: 98F07B05D831-1107226655
- Hand brake pivot block.icn
- (6.67 KiB) Downloaded 1 time
- report_98F07B05D831-1107226655_2025-04-05_13-59-41.zip
- (1.04 MiB) Downloaded 1 time
Re: Acorn V5.22 crashes when start from search N line
Known bug that was fixed in later versions. Upgrade to the latest CNC12 to fix this.
Re: Acorn V5.22 crashes when start from search N line < fixed>
