Hi
I found this NUC for a little over $100.
The CPU score is over 2000. But it’s listed on the laptop page. I didn’t know if that was a deal breaker.
https://www.pcliquidations.com/p151282-intel-nuc-8-mini
What do you think?
It’s going to be on a lathe if that is important
Thanks!
Mike
Does this look like a good CNC PC?
- CNC Control System Serial Number: 0479B7ADF2F3-1127192707
- Web Developer
Re: Does this look like a good CNC PC?
Hi Mike,
That Intel NUC should be fine for CNC12 use.
Centroid does not recommend Laptop form factors due to energy saving settings that are sometimes hidden away in the BIOS and may interfere with USB and networking, however 'Energy Efficient CPUs' like most Intel processors that end in U/P/T should be fine as long as they meet or exceed the minimum 1500 single core CPU score.
Be sure to follow TB309 and run the PC Tuner once you receive your new PC.
TB309
TB309
When requesting support please read this post first.
A fresh report makes it easier to assist you. To make a report check this post
Thanks you!
