All,
I'm confused why the G90 stays active after I've requested G91 causing my Zaxis to limit fault. Likely a setting like parameter3?
I've attached my report and the main folders I use in the Ncfiles folder. The main file to load is the 1759 in the workpiece.
This is NOT a traditional mill its a buffing machine that we G1 the X for linear motion and the Y and Z are top bottom buffs that follow a profile coordinating with the X.
I use D1 and D2 for buff diameters and no real "tool" D or H
I'm going to keep looking at this. Thanks!
Rob
Limits [X 0,-15] [Y 0,-4] [Z 0,-4] So a positive Z in G90 would be past a limit. Normally all negative direction.
(y)
=========================== - X +
(Z)
Likely and easy question about G90 G91 Modal Zaxis <Resolved>
- CNC Control System Serial Number: CNC12-m39-104028
- report_0008DC111213-0606220033_2025-03-22_15-56-30.zip
- (914.72 KiB) Downloaded 2 times
- _Machine Automation.zip
- (12.08 KiB) Downloaded 1 time
Rob Jackson
RJ Technical Services
Re: Likely and easy question about G90 G91 Modal Zaxis
I discovered my problem. Using the custom M25 macro interfered. I learned that às well trying to use M26 as another macro. Beware!
Rob Jackson
- Tech Support
Glad you got it figured out, thanks for reporting back!
