Debug Dump
Moderators: cnckeith, Joey
Adam Saucier
Plasma CNC Controller: Yes
Debug Dump
Post by Adam Saucier »
Had a debug dump message pop up yesterday, regarding the THC. What do I need to do?
Machine is still running fine.
Adam Saucier
Re: Debug Dump
Debug report
debug_dump1.txt
(2.49 MiB) Downloaded 1 time
Joey
Re: Debug Dump
Post by Joey »
Debug dump is usually the result of a job interruption or if the Float switch or Breakaway is tripped unexpectantly.
The Debug Dump will create a Plot file stored in the cncm folder.
The Plot will should the THC and Motion information leading up to the Debug dump. This is to help determine what the Table was doing that resulted in the interruption.
You can also Turn on The Debug/Plot to capture at every M62 Torch off in the G-code. This can be used for Reviewing how the THC is interacting with the Material / Profile settings.
You can enable a Plot capture at every M62 in the CNC12 Utility menu. F3 Plot
The Plots will be included in a report if you create one. You can also see the Latest Plot sitting in the CNCM folder.
