Hello,
I finished setup my sherline cnc with centroid CNC board and able to run the cnc, do any one know how to control sherline spindle motor with CNC board.. sherline motor has own speed control board And wondering if someone tried to control/monitor spindle speed from cnc centroid?
Sherline spindle motor control
Re: Sherline spindle motor control
This is a crude wiring daiagram on how I wired up the Shirline motor to work with the Acorn. It requires a KBMG -212 and a C-89. I was able to get full CNC control with forward an reverse. Cable 1 and 2 are just shieleded cables I used to wire things up. There are great You tube vidieos on the subject, non Sherline but aplicable. .
- KBMG-212 HOOK UP 001.pdf
- (174.16 KiB) Downloaded 7 times
i moved this thread to the Acorn forum.
